05-06-2024 09:57 PM
i want to login phone adapter configuration utility of this device, cisco and cisco can login ,but can't chang the set.
05-06-2024 10:00 PM
cisco/cisco
05-06-2024 10:48 PM
thank you friend,do you know how to disable web ui or http of this device
05-07-2024 04:52 AM
What is the intention of locking up the ATA?
If the ATA is loaded with Enterprise firmware, it can only receive configurations from CUCM. Anyone who browsing the IP address of the ATA will only get read-only access.
If the ATA is loaded with 3PCC/MPP firmware, how is anyone expected to configure, troubleshoot and monitor the ATA if web access is disabled?
05-07-2024 04:58 AM
thank you for your reply,because my company do not allow to enable port 80 or http,port 443 is ok,
05-07-2024 05:08 AM
HTTP can be disabled in CUCM.
05-07-2024 05:24 AM
thank you
05-06-2024 10:42 PM
05-06-2024 10:49 PM
thank you
friend, do you know how to disable web ui or http port 80 of this device
