10-27-2011 04:31 AM - edited 03-16-2019 07:44 AM
I want insert VIC3-4FXS/DID in my 2911 router.
Where two ways to do it:
1. Insert in HWIC slot
OR
2. Insert in NM module
What is the difference?
Solved! Go to Solution.
10-30-2011 10:43 AM
Now, about the difference: there really isn't any from a functional stand point; but if you choose to use a NM there may be additional HW considerations when it comes to PVDM card distribution between the motherboard's PVDM slots and the NMs slots.
Here are a couple of other usefull links:
DSP calculator (includes ISR G2 platforms):
http://www.cisco.com/web/applicat/dsprecal/dsp_calc.html
10-27-2011 05:22 AM
In V/HWIC slot.
You will also need PVDM3 DSP module.
10-27-2011 07:21 PM
Paolo, thanks a lot.
But can you explain the difference?
10-29-2011 06:13 AM
No need for NM.
Please remember to rate useful posts clicking on the stars below.
10-29-2011 06:34 PM
VIC3 cards can be inserted in both NMs and chassis HWICs. I don't believe you need PVDM3 cards specifically to support them but a recent IOS is required (anything in the 15T should be good). You may want to go through these two links:
http://www.cisco.com/en/US/products/ps10536/products_relevant_interfaces_and_modules.html#voicemod
http://www.cisco.com/en/US/prod/collateral/modules/ps5365/product_data_sheet0900aecd801c595e.html
10-30-2011 03:16 AM
Of course PVDM3 is required. No voice card can work without DSP.
10-30-2011 10:19 AM
I meant PVDM2 cards would also work; not just PVDM3. And just in case, IOS 12.4(20)T or later is required.
10-30-2011 10:43 AM
10-30-2011 03:41 PM
you might also want to consider the maintenance aspect and what slots support online removal cards should they fail.
11-02-2011 07:03 PM
Thanks everyone for reply!
