IP Telephony and Phones
Labels
Running callmanager 7.1.5 with unity connection. Callers hit a call handler and dial an extension. The extension rings  30 times then the call drops. Don't ask why the call rings 30 times!! Is there a place in callmanager where the maximum number or ...
gene by Level 1
  • 750 Views
  • 2 replies
Hi,i have impelmented a 2 voice gateway (VG)  on Two sites. Those VG are connected each one to one PBX :1- Site A : ->  The VG connected to the PBX by tow BRI                  -> The PBX has 5 Analogue Phone ( 100 VIP,101,102,103,104)2- Site B : The ...
habouzyad by Level 1
  • 297 Views
  • 1 replies
My Sip account is perfectly registered with the Sip provider, but the problem is that the router every time tried to registered another account (line 120) and the provider block the account.How can I do for block this issue?I've attached the configur...
bagnolini by Level 1
  • 504 Views
  • 3 replies
I have a problem that seems like it should be pretty simple but I've been banging my head against the wall for a couple days now and still nothing. I'm trying to take a number pattern (7135551[2-4]..) and put a plus in front of it (make it an e.164 n...
Resolved! Corlist
HelloHere is my corlist configuration. We need to restrcit User 'A' to Local calls only, but corlist is not working as expected. user 'A' can call local / national / international.dial-peer cor list Internationalmember Localmember 911member Nationalm...
seeking clarification on what the audio/video streams would look like if you were to wireshark the traffic for a multi point video conference call.example is a handful of remote sites with quickset C20's deployedcentral site has a few endpoints, + VC...
pdinapoli by Level 1
  • 1635 Views
  • 4 replies
