Which phones support "HTTPS support for configuration download"
Nadav
Level 7
Level 7
Hi everyone,
Can someone point me to documentation for which phones support this feature?
I see that it's been supported since CUCM 11:
"For secure configuration download, Unified Communications Manager Release 11.0 is enhanced to support HTTPS in addition to the HTTP and TFTP interfaces that were used in the earlier releases."
Dennis Mink
you would need to put your cluster in secure mode and first you need to make sure if you are running the restricted CUCM software, if not, forget it, you wont get it to run unless you rebuild the cluster with restricted software.
Please remember to rate useful posts, by clicking on the stars below.
My cluster is in mixed mode. But I imagine only certain phones support
HTTPS configuration download.
I believe (don’t have a cluster in front of me at the moment) that Unified Reporting Phone Feature List report has this as an option.
https://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/213546-unified-cm-phone-feature-list.html
Hi Jonathan,
I checked out the Feature List report on an 11.0.x cluster. I couldn't find a feature which matched what I'm looking for.
