who is using my license
klaus.seewald
Dear experts,
I have CUCM  with Cisco Prime License Manager - there I can see that I have one CUWL Standart License in use - and because I don´t have one installed, the System tells me that I need one license.
Where can I find, which part of configuration in CUCM is using/requesting  this license???
Need help
Best Regards,
Klaus
Jitender Bhandari
Hi Klaus,
On CUCM, You can go to System -> Licenses -> License Usage Report.
you will see hyperlink for licences type and it will tell you the usage there.
(Rate if it helps)
JB
Aman Soi
Hi Klaus,
you can find the same under CUCM Administration---System--Licensing -License Usage Report
Click on Users under Report for CUWL Standard.
Please find the attached snapshot.
regds,
aman
