06-12-2012 03:10 PM - edited 03-16-2019 11:38 AM
From this out put, you can see one g711ulaw call use 15 credits, but other 2 calls use 22 credits, why?
router1#sh voice dsp group all
DSP groups on slot 0:
dsp 1:
State: UP, firmware: 26.8.0
Max signal/voice channel: 32/32
Max credits: 480
num_of_sig_chnls_allocated: 32
Transcoding channels allocated: 0
Group: FLEX_GROUP_VOICE, complexity: FLEX
Shared credits: 190, reserved credits: 0
Signaling channels allocated: 32
Voice channels allocated: 13
Credits used (rounded-up): 290
Voice channels:
Ch01: voice port: 0/1/0:15.29, codec: g711ulaw, credits allocated: 15
Ch02: voice port: 0/1/0:15.31, codec: g711ulaw, credits allocated: 22
Ch03: voice port: 0/0/0:15.1, codec: g729br8, credits allocated: 22
Ch04: voice port: 0/0/0:15.3, codec: g729br8, credits allocated: 22
Ch05: voice port: 0/0/0:15.4, codec: g729br8, credits allocated: 22
Ch06: voice port: 0/0/0:15.6, codec: g729br8, credits allocated: 22
Ch07: voice port: 0/0/0:15.5, codec: g729br8, credits allocated: 22
Ch08: voice port: 0/0/0:15.7, codec: g729br8, credits allocated: 22
Ch09: voice port: 0/1/0:15.28, codec: g729br8, credits allocated: 22
Ch10: voice port: 0/0/0:15.9, codec: g729br8, credits allocated: 22
Ch11: voice port: 0/0/0:15.2, codec: g729br8, credits allocated: 22
Ch13: voice port: 0/1/0:15.30, codec: g729r8, credits allocated: 22
Ch14: voice port: 0/1/0:15.27, codec: g711ulaw, credits allocated: 22
Slot: 0
Device idx: 0
PVDM Slot: 0
Dsp Type: SP2600
06-12-2012 05:48 PM
Are therew any fax relay calls involved? The reason to have more credits (22) assigned per channel is that the router keeps the highest resource consuming call and memorizes the value of the credits. If you reload the routeryou should get the credit values back to 15.
Tere.
If you find this post helpful, please rate!
