Will QOS work with class on WAN interface !
kumar-brajesh
Will QOS will work in this way  where class is put on WAN interface where it should be service  policy.
router#sh run interface Se0/0/0.1
Building  configuration...
Current configuration : 239 bytes
interface  Serial0/0/0.1 point-to-point
bandwidth 2048
ip address XXXX
ip nat outside
frame-relay  interface-dlci 555
  class COS-OUT-S0/0/0.1
COS-OUT-S0/0/0.1 is defined as policy map  with class of voice and video.
When   checking on WAN int #sh policy-map  interface  Se0/0/0.1 , can see   output of service policy input/output with policy map  recpective   classes and packets match entries.Is  QOS working with this    configuration?
Appreciate any input on this.
Brajesh.
ashok_boin
Level 5
Level 5
Hi Brajesh,
It's perfectly working. You have configured FRTS.
http://www.cisco.com/en/US/docs/ios/12_0/qos/configuration/guide/qcfrts.html#wp4555
Regards...
-Ashok.
With best regards...
Ashok
ashok_boin
Level 5
Level 5
Hi Brajesh,
Regards...
-Ashok.
Ashok
Thanks Ashok.
I can see map class configured where service policy is configured.
map-class frame-relay COS-OUT-S0/0/0.1
frame-relay cir 1945600
frame-relay bc 20480
frame-relay be 0
frame-relay mincir 1945600
service-policy input COUNT-IN  >>>
service-policy output COS-OUT-S0/0/0.1>>>
Brajesh.
