09-16-2017 03:52 AM - edited 03-17-2019 11:10 AM
but i have a fxs interface for the 2611xm router I configured the router but i only make internal calls how do i send outside calls and associate it with the fxs interface? and how to configure a fxs interface? thanks for your answers
Solved! Go to Solution.
09-18-2017 05:41 AM
To run internally you need to configure CME, to connect to outside it depends on what type of circuit you have, i.e. standard phone line would be VIC-FXO line along with PVDMs. Keep in mind this router model is 13+ years behind having any updates on it as they were later replaced by ISR G1, ISR G2, and now ISR 4K, so anything you do will require a "time machine".
09-16-2017 12:10 PM
You first need to connect an outside line to your router via FXO port for example (assuming you have one). FXS is station line for analog devices (there are FXS-DID external trunks but those are rare). So, get FXO port, connect to external POTS line and then configure dial peers on the GW to router calls out.
09-17-2017 03:10 AM
version 12.4
hostname fabio
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
memory-size iomem 25
no network-clock-participate slot 1
no network-clock-participate wic 0
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.3.100
ip dhcp pool voice
network 192.168.3.0 255.255.255.0
default-router 192.168.3.100
dns-server 8.8.8.8 8.8.4.4
option 150 ip 192.168.3.100
lease infinite
ip dhcp pool default
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
option 150 ip 192.168.1.1
lease infinite
ip dhcp pool ciro
network 192.168.2.0 255.255.255.0
default-router 192.168.2.1
option 150 ip 192.168.2.1
lease infinite
ip dhcp pool fabio
network 192.168.4.0 255.255.255.0
default-router 192.168.4.1
option 150 ip 192.168.4.1
lease infinite
ip cef
interface ATM0/0
no ip address
shutdown
no atm ilmi-keepalive
dsl operating-mode auto
interface FastEthernet0/0
no ip address
duplex auto
speed auto
pppoe enable
pppoe-client dial-pool-number 2
interface FastEthernet0/1
description trunk-to-switch
no ip address
duplex auto
speed auto
interface FastEthernet0/1.1
description default vlan
encapsulation dot1Q 1 native
ip nat inside
no snmp trap link-status
interface FastEthernet0/1.2
description ciro vlan
encapsulation dot1Q 2
ip address 192.168.2.1 255.255.255.0
ip nat inside
interface FastEthernet0/1.3
description voice vlan
encapsulation dot1Q 3
ip address 192.168.3.100 255.255.255.0
ip nat inside
interface FastEthernet0/1.4
description fabio vlan
encapsulation dot1Q 4
ip address 192.168.4.1 255.255.255.0
ip nat inside
interface Dialer2
mtu 1492
ip address negotiated
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 2
ppp pap sent-username fabio password 0 aliceadsl
ip route 0.0.0.0 0.0.0.0 Dialer2
ip http server
no ip http secure-server
ip nat inside source list 102 interface Dialer2 overload
access-list 102 permit ip 192.168.0.0 0.0.255.255 any
control-plane
telephony-service
max-ephones 5
max-dn 5
ip source-address 192.168.3.100 port 2000
auto assign 1 to 5
max-conferences 4 gain -6
ephone-dn 1
number 0001
ephone-dn 2
number 0002
ephone-dn 3
number 0003
ephone-dn 4
number 0004
ephone 1
ephone 2
ephone 3
ephone 4
line con 0
password ciro
login
line aux 0
line vty 0 1
password ciro
login
line vty 2 4
login
end save this and my voip configuration ran the written configuration of the fxs interface, and the configuration association to fxs interface thanks.
09-17-2017 03:12 AM
09-17-2017 07:36 AM
I dont see any pots ports here, so are you looking for what voice-card you need?
Can you post "show diagnostics" and "show inventory".
09-17-2017 11:09 AM
09-18-2017 05:41 AM
09-18-2017 09:58 AM
but i would like to write the configuration for making external calls that i can call and receive with an interface fxs internally communicate already. thank you.
05-02-2018 04:51 PM
