06-28-2016 08:26 AM - edited 03-17-2019 07:22 AM
I try to install Windows Server 2012 R2 Standard on Cisco Advaced CCX WFO QM 10.0 OVA, but i get this error message: "We couldn´t find any drivers. To get a storage driver, click Load driver". The OVA contains 2 hard disks, 40GB and 146 GB, i try to install the OS on 40GB hard disk.
Someone have any idea?
Thanks.
Solved! Go to Solution.
06-28-2016 03:47 PM
Windows 2012 R2 Standard isn't supported for Cisco Unified Workforce Optimization Quality Management 10.0 Base Virtual Server Template. You may refer to the read me for the same:
http://www.cisco.com/web/software/286178530/108086/UCCX-WFO_QM1-VM_readme.txt
You can use Cisco Unified Workforce Optimization Quality Management 11.0 if you require OS support for Windows 2012 R2 (32 and 64 bit)
http://www.cisco.com/web/software/286178530/128275/UCCX-WFO_QM11.0_readme.txt
06-28-2016 02:11 PM
Check your ESXi version. There is a minimum to support 2012 R2
Graham
06-28-2016 03:47 PM
07-20-2016 10:13 PM
Thanks a lot Shanshank, i re-installed Windows Sever 2008 R2 on WFO QM 10.0 OVA without problem.
Regards.
