Windows Server 2016 and RTMT 11.5
wwatkin1977
Anyone had any luck getting RTMT 11.5 to run on Windows Server 2016?  Tried to run as administrator and Windows 7/8 compatibility mode, but no luck.
vincent.morton
We've got the same issue here, did you ever manage to find a solution or workaround?
fei he
Level 2
Level 2
What is solution/resolution for this? we have various version installed on Citrix (windows server 2k16) and across different issue:
1. RTMT 10.5 and 11.5 does not even launch
2. RTMT 12.5 launched and monitor cluster properly however when come to collect logs, dont see nodes at all.
Fei
b.winter
Anyone of you ever considired that RTMT 11.5 or earlier simply doesn't run (without any hacks) on Win 2k16?
