Wrong CLID when transfer call between CUCM and Ericson via H323
Hi all
I have a setup on customer site where CUCM and Ericson MD110 connect to each other via H323 Trunk. Everything working perfectly fine, except that when there is a call from outside or within a CUCM system and I try to transfer the call to the phone in ericson system, the CLID shown on ericson system is the phone that make a transfer call, not the original caller. I am quite sure that it realted to the configuration but I couldn't find any option on CUCM to fix this issue.
regards,
Pichan Pratummal
Have you checked the Outgoing IE delivery redirecting number on the H.323 GW setup in CUCM?
You can do a debug isdn q931 on the VGW to see if you send the redirecting number to the MD110.
Please remember to rate all useful posts
Response Signature
