wscmm-IPVOICEK9-M error
Jose Gomez
Hi, i have this messages,
%SCHED-2-EDISMSCRIT: Critical/high priority process MS_AC Dsprm Main may not dismiss. -Process= "MS_AC Dsprm Main", ipl= 0, pid= 44 -Traceback= 0x60A51F90 0x617C3BB0 0x60A40534 0x60A663B0 0x60A63FF8 0x60A658B8 0x604AD7F8 0x604A2640
when this message apears my conference doesn't work, and I need to reboot my CMM card in the 6500, and everything works fine.
Does anyone knows if this is BUG?.
I found this:
Error Message
%SCHED-2-EDISMSCRIT: Critical/high priority process [chars] may not dismiss
Explanation   Each process executes at a specified priority level. Higher-priority processes must use the new scheduler primitives, while lower-priority processes can use primitives from either the new or old scheduler. This message indicates that a higher-priority process attempted to use an old scheduler primitive.
here is part of the log file:
*Mar  1 00:00:05.767: %LINEPROTO-5-UPDOWN: Line protocol on Interface VoIP-Null0, changed state to up
*Mar  1 00:00:29.255: %LINEPROTO-5-UPDOWN: Line protocol on Interface NULL0, changed state to up
*Feb 28 18:00:29 Mexico: %SYS-6-CLOCKUPDATE: System clock has been updated from 00:00:29 UTC Fri Mar 1 2002 to 18:00:29 Mexico Thu Feb 28 2002, configured from console by console.
*Feb 28 18:00:29 Mexico: %SYS-6-CLOCKUPDATE: System clock has been updated from 18:00:29 Mexico Thu Feb 28 2002 to 18:00:29 Mexico Thu Feb 28 2002, configured from console by console.
*Feb 28 18:00:30 Mexico: %SYS-5-CONFIG_I: Configured from memory by console
*Feb 28 18:00:31 Mexico: %SYS-5-RESTART: System restarted --
Cisco IOS Software, Cat6K-lc Software (wscmm-IPVOICEK9-M), Version 12.4(16a), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Mon 10-Sep-07 22:07 by prod_rel_team
*Feb 28 18:00:31 Mexico: %SNMP-5-COLDSTART: SNMP agent on host MEXCOTLCCMM_220_23 is undergoing a cold start
*Feb 28 18:00:32 Mexico: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0, changed state to down
*Feb 28 18:00:32 Mexico: %SSH-5-ENABLED: SSH 1.99 has been enabled
*Feb 28 18:00:32 Mexico: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 10.103.151.9 started - CLI initiated
*Feb 28 18:00:33 Mexico: %LINK-3-UPDOWN: Interface GigabitEthernet1/0, changed state to up
*Feb 28 18:00:33 Mexico: %MSFW-6-DSPBRINGUP: Slot 1 DSPs are being brought up ...
*Feb 28 18:00:42 Mexico: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0, changed state to up
*Feb 28 18:00:53 Mexico: %MSFW-6-DSPUP: Slot 1 DSPs are UP
*Mar  1 00:00:54.520:
*Feb 28 18:01:01 Mexico: %SCP-5-ONLINE: Module online
Apr 11 04:04:04.894: [S] mgcp_msg_ack:6077,Updating (*)=10.103.220.62
Apr 11 10:48:20 Mexico: %SCHED-2-EDISMSCRIT: Critical/high priority process MS_AC Dsprm Main may not dismiss. -Process= "MS_AC Dsprm Main", ipl= 0, pid= 44 -Traceback= 0x60A51F90 0x617C3BB0 0x60A40534 0x60A663B0 0x60A63FF8 0x60A658B8 0x604AD7F8 0x604A2640
Apr 11 10:57:25 Mexico: %SCHED-2-EDISMSCRIT: Critical/high priority process MS_AC Dsprm Main may not dismiss. -Process= "MS_AC Dsprm Main", ipl= 0, pid= 44 -Traceback= 0x60A51F90 0x617C3BB0 0x60A40534 0x60A663B0 0x60A63FF8 0x60A658B8 0x604AD7F8 0x604A2640
Apr 11 11:00:29 Mexico: %SCHED-2-EDISMSCRIT: Critical/high priority process MS_AC Dsprm Main may not dismiss. -Process= "MS_AC Dsprm Main", ipl= 0, pid= 44 -Traceback= 0x60A51F90 0x617C3BB0 0x60A40534 0x60A663B0 0x60A63FF8 0x60A658B8 0x604AD7F8 0x604A2640
Apr 11 11:12:55 Mexico: %SCHED-2-EDISMSCRIT: Critical/high priority process MS_AC Dsprm Main may not dismiss. -Process= "MS_AC Dsprm Main", ipl= 0, pid= 44 -Traceback= 0x60A51F90 0x617C3BB0 0x60A40534 0x60A663B0 0x60A63FF8 0x60A658B8 0x604AD7F8 0x604A2640
Apr 11 12:33:53 Mexico: %SCHED-2-EDISMSCRIT: Critical/high priority process MS_AC Dsprm Main may not dismiss. -Process= "MS_AC Dsprm Main", ipl= 0, pid= 44 -Traceback= 0x60A51F90 0x617C3BB0 0x60A40534 0x60A663B0 0x60A63FF8 0x60A658B8 0x604AD7F8 0x604A2640
Apr 11 12:35:25 Mexico: %SCHED-2-EDISMSCRIT: Critical/high priority process MS_AC Dsprm Main may not dismiss. -Process= "MS_AC Dsprm Main", ipl= 0, pid= 44 -Traceback= 0x60A51F90 0x617C3BB0 0x60A40534 0x60A663B0 0x60A63FF8 0x60A658B8 0x604AD7F8 0x604A2640
Apr 11 14:05:58 Mexico: %SCHED-2-EDISMSCRIT: Critical/high priority process MS_AC Dsprm Main may not dismiss. -Process= "MS_AC Dsprm Main", ipl= 0, pid= 44 -Traceback= 0x60A51F90 0x617C3BB0 0x60A40534 0x60A663B0 0x60A63FF8 0x60A658B8 0x604AD7F8 0x604A2640
Apr 11 14:56:28 Mexico: %SCHED-2-EDISMSCRIT: Critical/high priority process MS_AC Dsprm Main may not dismiss. -Process= "MS_AC Dsprm Main", ipl= 0, pid= 44 -Traceback= 0x60A51F90 0x617C3BB0 0x60A40534 0x60A663B0 0x60A63FF8 0x60A658B8 0x604AD7F8 0x604A2640
Apr 11 15:00:11 Mexico: %SCHED-2-EDISMSCRIT: Critical/high priority process MS_AC Dsprm Main may not dismiss. -Process= "MS_AC Dsprm Main", ipl= 0, pid= 44 -Traceback= 0x60A51F90 0x617C3BB0 0x60A40534 0x60A663B0 0x60A63FF8 0x60A658B8 0x604AD7F8 0x604A2640
Apr 11 16:12:20 Mexico: %SCHED-2-EDISMSCRIT: Critical/high priority process MS_AC Dsprm Main may not dismiss. -Process= "MS_AC Dsprm Main", ipl= 0, pid= 44 -Traceback= 0x60A51F90 0x617C3BB0 0x60A40534 0x60A663B0 0x60A63FF8 0x60A658B8 0x604AD7F8 0x604A2640
Apr 11 16:31:58 Mexico: %SCHED-2-EDISMSCRIT: Critical/high priority process MS_AC Dsprm Main may not dismiss. -Process= "MS_AC Dsprm Main", ipl= 0, pid= 44 -Traceback= 0x60A51F90 0x617C3BB0 0x60A40534 0x60A663B0 0x60A63FF8 0x60A658B8 0x604AD7F8 0x604A2640
Apr 11 16:56:52 Mexico: %SCHED-2-EDISMSCRIT: Critical/high priority process MS_AC Dsprm Main may not dismiss. -Process= "MS_AC Dsprm Main", ipl= 0, pid= 44 -Traceback= 0x60A51F90 0x617C3BB0 0x60A40534 0x60A663B0 0x60A63FF8 0x60A658B8 0x604AD7F8 0x604A2640
Yes you are correct Jose, there were no Heart Beat error message found in the logs and heart beat issue were found in lower version since you are already on higher .
Just  keep update if you find relevant information from TAC.
Br, Nadeem Please rate all useful post.
5 Replies 5
Nadeem Ahmed
Hello Jose,
How frequent this issue is happening? Also send me the show version and try to decode the traceback and see if its hitting any defects
Br,
Nadeem
Hi Nadeem, the issue happens every three or four months, the problems is that i need to reset the CMM card every time it happens, i am not sure if it is a BUG.
this is what the show version command shows:
EXCOTLCCMM_220_23#show version
ROM: System Bootstrap, Version 12.2(1r)T2, RELEASE SOFTWARE (fc1)
MEXCOTLCCMM_220_23 uptime is 1 day, 22 hours, 40 minutes
System restarted at 10:53:04 Mexico Tue Apr 14 2015
System image file is "bootflash:wscmm-ipvoicek9-mz.124-16a.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-SVC-CMM Cat6k Voice Linecard (R7000) processor (revision 0xFF) with 196608K/65536K bytes of memory.
Processor board ID SAD11400149
R7000 CPU at 400MHz, Implementation 39, Rev 3.3, 256KB L2 Cache
Last reset from power-on
3 FastEthernet interfaces
1 Gigabit Ethernet interface
31 Serial interfaces
6 Channelized E1/PRI ports
32768K bytes of processor board bootflash (Read/Write)
Hello Jose,
I tried decoding the trace but unfortunately don't find any existing bug on this IOS version 12.(16a). there were couple of bug are there but those related to Heart beat issue causing DSP to reset and propagate the same error.
I would suggest either upgrade to higher version open a TAC just to double check if new bug is hitting.
Br,
Nadeem Ahmed
Hi Nadeem, well i have seen those bugs related to hert beat issue, but as you can see in the log there isn't anything about heat beat issue. So i wil try to opene a case with TAC, just to be sure.
I do apreciate your time!
Thanks!!!
