Xmedius fax - SIP Trunk to MGCP GW
rcrumm_2
Level 2
Level 2
I am a troubleshooting xmedius fax issue. I cannot complete a fax. There is no fax detected, error code 602.
It was working before I started, but now it is not.
I have CUCM 8.5.1/Xmedius 6.5 and a MGCP GW.
Any thoughts are welcomed.
Rrandall
Aashish Jolly
Hi Randall,
   Could you let us know the fax protocol you're using. I'm assuming you're using T.38 and I assume the below call flow
PSTN Fax --> E1 PRI --> Cisco Voice GWY --> MGCP --> CUCM --> SIP Trunk --> Xmedius
If the above call flow is correct, could you verify if the configuration on MGCP gateway is as per the document below
http://www.cisco.com/en/US/docs/ios-xml/ios/voice/fax/configuration/12-4/vf-cfg-t38-fxrly.html#GUID-BB946909-0343-4E9D-AE79-866FC2B8ADF9
At the same time, verify the controller has no slips, use the command show controller e1 and make sure there are no slip seconds or any other error.
  Let us know how it goes.
Aashish
