zain ksa SIP registretion congiguretion on cme
paramesh
hi all ....
we have Cisco cme 3900 series
we are trying to config the sip trunk from zain . but that sip registration is always rejecting from  zain system. we  contact to zain  but they are all so not perfect to guide us what was the problem
i can ping there IP address  but when we sending registration request its not reaching on zain sip server
so anybady have experience  zain sip configuration
please help us
HARIS_HUSSAIN
Just do a debug ccsip messages and past the output here. Also paste your show run.
*** Please rate helpful post; Mark "Accept as a Solution" if applicable
Haris
5 Replies 5
HARIS_HUSSAIN
Haris
Dear  haris
please find the file which you ask
Don't mark the Thread as Solved as the issue is not yet resolved., Remove the same so that you will get more inputs from experts here.
As per the logs, the messages are going to Provider but we are not getting any reply back from them. try to change the username from +966135190231 to one without country code like 0135190231 OR 135190231
Try to change the
Below is sample config I use with Etisalat
sip-ua
credentials number 047778888 username 47778888.etisalat password 7 0000060B0942 realm etisalat.com
authentication username 47778888.etisalat password 7 14A13407A0S6011D
no remote-party-id
retry invite 10
retry response 4
retry bye 1
retry register 10
timers trying 1000
timers expires 360000
timers connect 100
timers buffer-invite 500
registrar dns:47778888.etisalat expires 3600
sip-server dns:47778888.etisalat
Sorry Am new in this community that's why i don't know what was that mean that's why i click accept i think that accept only your replay
any way i will try that one also
so we can consider that the issue from the ISP side not from us
al3mary
In invite message should include" user=phone" parameter.
