04-24-2021 08:56 AM - edited 04-24-2021 07:41 PM
my outbound fax calls to pstn doesn't work...please see call flow below
fax server--SIP trunk--cucm---mgcp gw--pstn
Internal calls are working fine.
Invite-100 trying--183 session in progress--UPDATE--481 call doesn't exist
I would appreciate if someone can get back to me.
***if you see ++ before a number that just a typo
04-24-2021 10:41 AM
Internal calls are working fine. Internal calls from phone to Fax server? What about incoming call from PSTN to FAX ?
From: sip:4031112222@171.20.71.210:5060;tag=BAC7A25B7D10
To: sip:+14032223345@192.168.175.252:5060
Call-ID: 336274AE-4547-4417-B4B6-18B380950ED8@171.20.71.210
CSeq: 101 INVITE
SIP/2.0 183 Session Progress
Via: SIP/2.0/UDP 171.20.71.210:5060;branch=z9hG4bK-5C2583E84A69
To: sip:+14032223345@192.168.175.252:5060;tag=167043904~8a8ec789-a441-442a-a33a-7f83cbca7314-96467356
SIP/2.0 481 Call Does Not Exist
Via: SIP/2.0/UDP 192.168.175.252:5060;branch=z9hG4bKebb25f68e49a17
From: sip:++14032223345@192.168.175.252:5060;tag=167043904~8a8ec789-a441-442a-a33a-7f83cbca7314-96467356 >> header is in other direction.
To: sip:4031112222@171.20.71.210:5060;tag=BAC7A25B7D10
04-24-2021 10:44 AM
Internal Calls----one eFax to this eFax server
Incoming from PSTN to FAX---works
04-24-2021 11:04 AM
192.168.175.252--CUCM call manager
171.20.71.210---fax server (this ip is also configured on CUCM SIP Trunk) as a destination address port 5060
fax from 4031112222
fax to 14032223345
2nd cucm is -192.168.175.220
I hope that helps.
04-24-2021 09:31 PM
Since only outgoing Fax are not working, Does the fax sever trunk has access to CSS which can call outside numbers ?
What protocol you use for fax, t.38 or Pass through ?
04-25-2021 06:33 PM
yes...it does.
SIP Trunk CSS (Inbound calls) contains PT for route pattern
04-25-2021 09:26 PM
The default configuration for Unified CM SIP trunks is to use Delayed Offer, if your Fax use early offer you need to make your sip trunk for early offer.
Check MTP required on the SIP trunk configuration page or if you are on CUCM 8.5 or later go to the SIP Profile (Device > Device Settings > SIP Profile) and check "Early Offer support for voice and video calls (insert MTP if needed)".
04-26-2021 06:50 AM
will do....let you know little later this week. Thanks
