E1 only DSP Gateway question
iptuser55
Level 6
Level 6
I currently have a router with the following modules
NM-HDV2-2T1/E1 with VWIC2 2MFT T1/E1 and a separate VWIC3-2MFT T1/E1
All to be used as E1 so giving 6x  E1 ports in a 3945 IOS 15.X router. The router will only be used for E1 no conf or transcoding. I looked at the DSP Calculator and it suggested I do not need any DSP`s - Is this correct ?
I just need a second opinion on this - If we do not do any conf or transcoding it seems no DSP are required? - Is this right
I need to move VWIC between different routers to free some up and then send them to different locations but I need to make sure I do not need to move DSP`s as well
thanks
5 Replies 5
iptuser55
Level 6
Level 6
Also can I use a vwic 3 with a nm-hdv2 module
acampbell
Here is my results from the DSP Calclator :-
Router: 3945
IOS: 15.1(4)M
DSP Modules Required:
PVDM3-128: 1
PVDM2-64: 1
DSP Module Allocation:
Router Slot 0: 120 Voice (94%) 8 Available (6%)
PVDM Slot 0/0: PVDM3-128
Router Slot 1: 60 Voice (94%) 4 Available (6%)
PVDM Slot 1/0: PVDM2-64
Router Slot 2:
Router Slot 3:
Router Slot 4:
Call Volume Allocation:
Router Slot 0 Low Med High
Slot 0/0: VWIC3-2MFT-T1/E1(E1) 60
Slot 0/1: VWIC2-2MFT-T1/E1(E1) 60
Router Slot 1: NM-HDV2-2T1/E1(E1) 60
HtH
Alex
Regards, Alex. Please rate useful posts.
Hi Alex
thanks for getting back to me however when I entered the same info I got no dsp required- where am I going wrong
Router slot 0
0/0 VWIC3 60 channels
0/1 VWIC3 60 channels
Slot 1 NM-HDV2 60 channels
I dont think you are inputting the number of channels you are proposing to use
You need to input up to 30 channels for each bearer.
Alex
iptuser55
Level 6
Level 6
that`s correct, saw it enterd 60 but that was only "potential" doh !!
