Duo AuthProxy 5.7.1
bacjac38
Level 2
Level 2
We’re still running v5.7.1 and have to support our global legacy infrastructure. We had to retire a server that was our backup authproxy server running this version. I’m looking for the 5.7.1 installer in order to install it on an existing server and keep the version aligned as required.
DuoPablo
Hi @bacjac38 ,
You can download older versions of Duo software by replacing latest with the version you are seeking, based on the Downloads and Checksums page.
For example, if you are using Windows for your Auth Proxy: https://dl.duosecurity.com/duoauthproxy-5.7.1.exe
Hope this helps!
DuoPablo
Hi @bacjac38 ,
Hope this helps!
bacjac38
Level 2
Level 2
It helps indeed - thanks so much!
