ASR-920-24SZ Problem with 24x1GE ports?
Vincent5
I have a few ASR-920-24SZ which I'm testing.
All ports light up yellow. When plugging in a GLC-SX-MM or GLC-SX-MMD the it gets detected in the CLI. But I'm not getting any green uplink. (all SFPs and fiber cable is working tested in many other cisco devices). When I test with a Cisco GLC-T the SFP ports become UP/UP,  but the port LED Indication becomes OFF.
The 4x10GE works on all. Lights up green and gives uplink.
All the ports show they are. I've tested do "interface range" then shutdown, no shutdown.
Router#show ip int br
Interface              IP-Address      OK? Method Status                Protocol
GigabitEthernet0/0/0   unassigned      YES NVRAM  down                  down
GigabitEthernet0/0/1   unassigned      YES NVRAM  down                  down
GigabitEthernet0/0/2   unassigned      YES NVRAM  down                  down
GigabitEthernet0/0/3   unassigned      YES NVRAM  down                  down
GigabitEthernet0/0/4   unassigned      YES NVRAM  down                  down
GigabitEthernet0/0/5   unassigned      YES NVRAM  down                  down
GigabitEthernet0/0/6   unassigned      YES NVRAM  down                  down
GigabitEthernet0/0/7   unassigned      YES NVRAM  down                  down
GigabitEthernet0/0/8   unassigned      YES NVRAM  down                  down
GigabitEthernet0/0/9   unassigned      YES NVRAM  down                  down
GigabitEthernet0/0/10  unassigned      YES NVRAM  down                  down
GigabitEthernet0/0/11  unassigned      YES NVRAM  down                  down
GigabitEthernet0/0/12  unassigned      YES NVRAM  down                  down
GigabitEthernet0/0/13  unassigned      YES NVRAM  down                  down
GigabitEthernet0/0/14  unassigned      YES NVRAM  down                  down
GigabitEthernet0/0/15  unassigned      YES NVRAM  down                  down
GigabitEthernet0/0/16  unassigned      YES NVRAM  down                  down
GigabitEthernet0/0/17  unassigned      YES NVRAM  down                  down
GigabitEthernet0/0/18  unassigned      YES NVRAM  down                  down
GigabitEthernet0/0/19  unassigned      YES NVRAM  down                  down
GigabitEthernet0/0/20  unassigned      YES NVRAM  down                  down
GigabitEthernet0/0/21  unassigned      YES NVRAM  down                  down
GigabitEthernet0/0/22  unassigned      YES NVRAM  down                  down
GigabitEthernet0/0/23  unassigned      YES NVRAM  down                  down
Te0/0/24               unassigned      YES NVRAM  down                  down
Te0/0/25               unassigned      YES NVRAM  down                  down
Te0/0/26               unassigned      YES NVRAM  down                  down
Te0/0/27               unassigned      YES NVRAM  down                  down
GigabitEthernet0       unassigned      YES NVRAM  down                  down
Router#
LED Indication explained from the manual
  1. LEDLED StateIndication
    Labeled same as the SFP port numberGreenLink up in 1000Base-X/100Base-FX
     Blinking GreenActivity in 1000 Base-X/100Base-FX
     YellowFault/Error
     OffLink down
Output from show license and show version:
Router#show license all
License Store: Primary License Storage
StoreIndex: 0   Feature: metroaccess                       Version: 1.0
        License Type: Permanent
        License State: Active, In Use
        License Count: Non-Counted
        License Priority: Medium
StoreIndex: 1   Feature: 24portGE-4port10GE                Version: 1.0
License Store: Built-In License Storage
StoreIndex: 0   Feature: advancedmetroipaccess             Version: 1.0
        License Type: Evaluation
        License State: Active, Not in Use, EULA not accepted
            Evaluation total period: 8  weeks 4  days
            Evaluation period left: 8  weeks 4  days
            Period used: 0  minute  0  second
        License Priority: None
StoreIndex: 1   Feature: metroipaccess                     Version: 1.0
StoreIndex: 2   Feature: metroaccess                       Version: 1.0
        License State: Inactive
Router#sh ver
Cisco IOS XE Software, Version 03.14.00.S - Standard Support Release
Cisco IOS Software, ASR920 Software (PPC_LINUX_IOSD-UNIVERSALK9_NPE-M), Version 15.5(1)S, RELEASE SOFTWARE (fc5)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Thu 20-Nov-14 18:25 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2014 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.  For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
Router uptime is 27 minutes
Uptime for this control processor is 30 minutes
System returned to ROM by reload
System image file is "bootflash:/asr920-universalk9_npe.03.14.00.S.155-1.S-std.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: metroaccess
Next reload license Level: metroaccess
cisco ASR-920-24SZ-M (Freescale P2020) processor (revision 1.2 GHz) with 916491K/6147K bytes of memory.
Processor board ID XXXXXXXXXXXXXX
24 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
3670016K bytes of physical memory.
1328927K bytes of SD flash at bootflash:.
Would be happy with any help here, best regards
9 Replies 9
Vincent5
I just tested my SFPs and fiber cable in a known working Cisco ASR-920. Show uplink directly in the 24X1G ports.
balaji.bandi
try - no negotiation auto , still issue
after plug the SFP post show interface x/x and show run interface x/x, show interface x/x tran
BB
Router(config)#interface gigabitEthernet 0/0/0
Router(config-if)#no neg
Router(config-if)#no negotiation au
Router(config-if)#no negotiation auto
Router(config-if)#
Router#show
*Feb 16 08:59:10.414: %SYS-5-CONFIG_I: Configured from console by consoleint
Router#show interfaces giga
Router#show interfaces gigabitEthernet 0/0/0
GigabitEthernet0/0/0 is down, line protocol is down
  Hardware is 24xGE-4x10GE-FIXED-S, address is 84b8.0223.d880 (bia 84b8.0223.d880)
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Keepalive set (10 sec)
  Full Duplex, 1000Mbps, link type is force-up, media type is SX
  output flow-control is unsupported, input flow-control is on
  Last input never, output never, output hang never
  Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 watchdog, 0 multicast, 0 pause input
     0 packets output, 0 bytes, 0 underruns
     0 output errors, 0 collisions, 4 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
I have the SFP connected to another ASR-920 which I did the same command on.
Router(config-if)#no auto
Router(config-if)#
Router#
Router#
Router#
Router#show int
*Feb 16 08:53:57.903: %SYS-5-CONFIG_I: Configured from console by consolegi
  Hardware is 24xGE-4x10GE-FIXED-S, address is 84b8.0223.d600 (bia 84b8.0223.d600)
Still no uplink.
I also tested SFP in same ASR920 in Gigabitport 0/0/0 and 0/0/2
Router# show inter
Router# show interfaces giga
Router# show interfaces gigabitEthernet 0/0/2
GigabitEthernet0/0/2 is down, line protocol is down
  Hardware is 24xGE-4x10GE-FIXED-S, address is 84b8.0223.d602 (bia 84b8.0223.d602)
Router#
Output from show running config gigabit 0/0/0 + 0/0/2
Router#show running-config interface gigabitEthernet 0/0/0
Building configuration...
Current configuration : 74 bytes
interface GigabitEthernet0/0/0
 no ip address
 no negotiation auto
end
Router#show running-config interface gigabitEthernet 0/0/2
interface GigabitEthernet0/0/2
 no ip address
 no negotiation auto
end
output from the show interfaces gigabitEthernet 0/0/0 transceiver
Router#show interfaces gigabitEthernet 0/0/0 transceiver
Diagnostic Monitoring is not implemented.
Router#show interfaces gigabitEthernet 0/0/2 transceiver
Router#
is this production setup ? or stll setup in intial stage.
if this intial stage, for testing all working or not, take fibre patch lead connect Gi 0/0/0 to Gi0/0/2 see if the ports come up ?
BB
It's not in production yet.
write erase
reload
skip initial setup Y/N? Yes
Afterwards I wait for the ports to wake up. Then I test them.
Let us know how it goes, do not forget to post the requested output if still issue.
BB
No success. And the output that I sent first times was after doing the erase startup-config and reloading.
I no longer have access to these routers anymore but if someone have had this issue or know what I have done wrong I'm still interested to know.
Vincent5
I tried install the licenses that are on the bootflash:
But it said they are already installed and activated.
andybailey
show platform if version for R0 last two digits is "00" field notice bug  with version 155-1.S
