ATM module for 3745
abaghir
Hello All,
currently we are in the processing of requesting an ATM link with our carrier provider, we have been told that our inteface should be ATM UNI 4.0 standard and the interface must be G.703
Appreciate if someone can help in what should be the part number of the ATM module that we should order from cisco.
spremkumar
Level 9
Level 9
hi
I would prefer cheking the following datasheets to find out the ATM modules supported by 3745 and the module which serve ur purpose..
http://cisco.com/en/US/products/hw/routers/ps282/products_data_sheet09186a008009203f.html
http://cisco.com/en/US/products/hw/routers/ps282/products_data_sheet09186a0080088753.html
regds
asimkhan207
ATM PORT ADAPTOR PA-A3
G'day,
You can get the following ATM network modules for the
3745:
NM-1A-T3 1-Port DS3 ATM Network Module
NM-1A-E3 1-Port E3 ATM Network Module
NM-1A-OC3MM-EP 1-Port OC-3 Multimode ATM Enhanced performance NM for 3745
NM-1A-OC3SMI-EP 1-Port OC-3 ATM Enhanced perf Singlemode Int Reach NM 3745
NM-1A-OC3SML-EP 1-Port OC-3 ATM Enhanced Perf Singlemode Long NM 3745
NM-1T3/E3 One port T3/E3 network module
Hope that helps - pls rate the post if it does.
Paresh
