12-07-2016 11:11 PM
Hi All,
I needs some advice on the suitability of a Cisco ASR 920 that will act as a PE router
We are looking to terminate customer ethernet circuits into our PoP to provide Internet, MPLS, VPLS services. Our provider will aggregate the customer tails onto a single 1Gbps port with each customer being presented as a separate VLAN. Customer A VLAN 101, Customer B VLAN 102 etc.
Each customer will then have a CE installed that will present a different port for Internet, MPLS etc with a different inner VLAN tag being pushed to differentiate the service. So internet services arriving in our PoP for Customer A will have an inner tag of 11 and outer tag of 101
My plan is to terminate the ethernet circuit from our provider onto a port on the ASR 920 and then using EFPs and dot1q matching to place the traffic into the correct service. Internet traffic will be placed into a bridge domain in the global VRF and MPLS traffic will be placed into a bridge domain in the customer’s VRF.
Does this sound like a feasible solution? Carrier Ethernet is new to me so please let me know if I'm completley on the wrong track here
Thank you
Solved! Go to Solution.
12-09-2016 01:27 AM
That depends on how is the link between ASR 920 and ASR1001-X is configured,
If it’s just a L2 trunk then:
On ASR920 you can use the same EFP config style on both:
the interface facing your provider
the interface facing ASR1001-X
and then you can join the particular EFPs (service instances) on these interfaces via common bridge domain.
But bridge domain works like a switch so it will start learning mac addresses, so I’m thinking that in this case you should be able to disable mac-address learning for these p2p bridge-domains.
On ASR1001-X side of the link to ASR920 you’d use the same EFP config style but here you’d use the IP address and VRF on the particular EFP(service instance).
If it’s L3/MPLS then:
You can use PW/xconnect configuration on ASR920 (my example service instance 3 -linked to l2vpn xconnect context con1)
But on ASR1001-X side you would need to use “PW Head End” (PWHE) feature to terminate the PW on an L3 interface and the PWHE is not supported on IOS-XE, I think.
adam
12-08-2016 05:53 AM
The ASR920 was exactly designed for what you described.
The config might look something like this:
interface GigabitEthernet0/0/0
service instance 1 ethernet
encapsulation dot1q 101 second-dot1q 11
vrf forwarding internet-vrf
ip address 10.1.1.1 255.255.255.252
service instance 2 ethernet
encapsulation dot1q 101 second-dot1q 12
rewrite ingress tag pop 1 symmetric
bridge-domain 100
service instance 3 ethernet
l2 vfi PE2-VPLS-A manual
vpn id 100
neighbor 10.1.1.1 encapsulation mpls
neighbor 10.3.3.3 encapsulation mpls
bridge domain 100
member GigabitEthernet0/0/0 service-instance 3
member Pseudowire 100
template type pseudowire eompls
encapsulation mpls
interface Pseudowire 100
source template type pseudowire test
neighbor 10.13.13.13 1
adam
12-08-2016 07:03 AM
Hi Adam,
Thanks for this. Quick question (hopefully) - the L3 interface for the Internet VRF needs to be configured on a Cisco ASR1001-X and not on the ASR 920. The ASR1001-X will be directly connected to the ASR 920.
To acheive this, will I need to modify the EFP 'service instance 1 ethernet' in your above example and place it in a bridge domain and then do the same on the ASR1001-X with a BDI interface?
12-09-2016 01:27 AM
adam
12-09-2016 05:00 AM
Thanks Adam
