Configuration of opposing devices when using ASR920 mLACP
YEH
We are using a mLACP with an ASR920 router in an Active/Standby configuration.
The opposite device will be a Catalyst switch (stacked), but we have the following on the Catalyst switch side
Is it necessary to set lacp max-bundle 1 and lacp port-priority to match?
If not, I would appreciate an answer to that question.
■ASR920#1 (Active)
interface Port-channel1
 lacp fast-switchover
 lacp max-bundle 1
 mlacp lag-priority 10
 mlacp interchassis group 1
■ASR920#2 (Standby)
 lacp max-bundle 1
 mlacp lag-priority 100
■Catalyst Switches
 lacp max-bundle 1
GigabitEthernet 1/0/1
 lacp port-priority 10
 channel-group 1 mode active
GigabitEthernet 2/0/1
 lacp port-priority 100
balaji.bandi
In general, the case is not required to build Port-channel.
lacp max-bundle
To define the maximum number of active bundled LACP ports allowed in a port channel, use the lacp max-bundle command in interface configuration mode. To return to the default settings, use the no form of this command.
BB
Hi @balaji.bandi
Thank you very much.
I understand that lacp port-priority and lacp max-bundle settings are not required on the Catalyst switch.
