L2 VS VPLS
belaljordan
Hi to all,
which is better L2 technology ( implemented with 802.1q ) or VPLS technology .
8 Replies 8
mtsb
I would vote for VPLS. I have lot of flexibilites and options to use like...
1. VC/VFI scaling
2. H-VPLS where you dont need to bother about configuring all peer PE routers when adding more PEs,
3. BGP AD where you can auto discover your neighbors
4. Gives us option to use mpls related features like TE/FRR etc.
5. We can use port-channel as core facing card which is helpful in swithcing huge customer traffic.
and many more...
Refer to the attached doc that gives you more details on vpls.
Thanks.
Madhu
Thank you for your advice
Hi madhu,
how i can configure Internet access on H-VPLS although no ip address configured under the interface vlan  as the following
interface Vlan #
no ip address
xconnect vfi l2vpn
if you  connecting  different sites using VPLS , then you have a closed  virtual circuit
Can I have configure Internet interface vlan  in the same VPLS domain and control which CE router can access this Internet Vlan by configure the attachment circuit on the specific untagged ethernt packet or trunk
Iam not sure about your question. Do you want to have an ip address configured on the interface where you have xconnect? If so you do usnig routed-vpls solution I believe.
Madhu
Thanks for you help
Yes I want this but do you have any documentation about r-vpls or any configuration example.
Sorry for getting back late but you can refer to RFC. I have documents which are internal ones and I cannot share with you right now.
http://tools.ietf.org/html/draft-sajassi-l2vpn-rvpls-bgp-00
