QnQ Solution for Layer2 MPLS Customers
guruprasadr
Level 7
Level 7
Hello Experts,
Requirement: QnQ Solution for L2 MPLS Customers.
Kindly advice on the Solution and share your inputs.
Thanks in advance for the Help.
Best Regards,
Guru Prasad R
14 Replies 14
Giuseppe Larosa
Hello Guru,
Vlan based EoMPLS should be able to support Q in Q too you may need to tune MTU settings to support the increased overhead.
see fig. 4 on
http://www.cisco.com/en/US/netsol/ns341/ns396/ns223/networking_solutions_white_paper09186a00800a11a2.shtml
Hope to help
Giuseppe
jimmy.anderson
You will need to make sure you are terminated directly on a card that supports QinQ termination (ES20 cards). If you are not connected to one of these cards, you can xconnect the EoMPLS to a pair of boxes that both have ES20 cards and are directly connected. Then you can xconnect to box#1, strip the outer tag, and then push the inner tag to box#2 and then you can do whatever you want with the inner tag.
thomas.feichter
i think you have 2 possibilities:
- EoMPLS port mode
- dot1q tunnel over MPLS
EoMPLS port mode:
In this config the port is completely transparent.
interface X/Y
no switchport
no ip address
xconnect 50 encapsulation mpls
Dot1q-tunnel config:
interface X/Y
switchport
switchport access vlan 100
switchport mode dot1q-tunnel
switchport nonegotiate
l2protocol-tunnel cdp
l2protocol-tunnel stp
l2protocol-tunnel vtp
no cdp enable
interface Vlan100
no ip address
xconnect 100 encapsulation mpls
! the VC-ID 100 must not match with vlan id
I have tested this scenarios on 3750ME and 7600 with the WS-X6748-GE-TX linecard (also for a L2 solution for customers).
Works fine (in port mode ther is a little bug:cdp don't works).
So, if you do not have port density issues, I suggest the port mode.
If you have problems to bring up the service, check the mtu values! (maybe on interface vlan)
Best regards,
Thomas
HI Thomas,
Great Post Update !
Would like to clarify few points:
Normal L2 Customer Configuration:
interface X/Y
no switchport
no ip address
interface X/Y
switchport
no cdp enable
>> As per my understanding, Here VLAN ID 100 means Dot1Q Tag VLAN.
I did not fully understand the below configuration:
interface Vlan100
no ip address
In an L2-MPLS Scenario, the VC id should be common end-to-end to create a Circuit.
How does a Outer VLAN Tag of "100" is stripped of while creating a Circuit. Also, on what basis the L2 Circuit negotiate in your Case Study.
Request your Help / Advice.
Thanks in Advance.
Best Regards,
Guru Prasad R
on the dot1q tunnel mode the vlan id 100 means the vlan tag.
however, exactly I don't know how the Vlan info is encoded in the MPLS packets...
And the VC-ID must match on both 2 PE's.
I have made only the functional tests at this time..
Thomas
HI Thomas,
Can you please post the sample configurations,
Interface configurations of PE-A and PE-B
as well the QnQ Tunnel configuration on the Switch.
Best Regards,
Guru Prasad R
Hi guru,
here the configs:
QinQ Tunnel:
PE_A:
interface GigabitEthernet4/5
switchport
switchport access vlan 1602
interface Vlan1602
mtu 1900
no ip address
xconnect 1602 encapsulation mpls
no spanning-tree vlan 1602
PE_B:
switchport
interface Vlan1602
mtu 1900
no ip address
Here the port mode:
PE_A:
interface GigabitEthernet4/10
mtu 1900
no ip address
xconnect 150 encapsulation mpls
PE_B:
interface GigabitEthernet4/14
mtu 1900
no ip address
Note the mtu value. I recommend to use a big mtu on your MPLS core to avoid issues. Check the smallest mtu on your network (where mpls packets can flow) and set on all devices/interfaces where run mpls to that value.
However on the customer ports, you can manually set a smaller mtu (min 1504 to allow 1500byte dot1q packets).
I my example the mtu to customer is set to 1900.
Remember that if the mtu don't matches on the 2 PE's, the EoMPLS connection don't will go up.
Tom
Hi Thomas,
I notice that you have applied a xconnect to an SVI per:
interface Vlan1602
mtu 1900
no ip address
We tried the same a while back but could only get the xconnect to work when configured on the physical port.
What was your hardware in this setup? I tried it on a 7600, Sup32, and 61xx and 65xx series line cards. Suspect adding a SIP-400 or ES-20 facing the WAN may help matters, but can't confirm this anywhere.
Kent.
I user on the ports to the core SIP-400 with SPA-2x1G-V2. RSP-720-3CXL.
Sorry, I don't know exactly the HW requirements. On the datasheet of the SUP-32/Linecards you will find this informations.
Ragards,
Thomas
HI Thomas,
Have rated your post. I would/will update with some clarifications/results after my testing.
Best Regards,
Guru Prasad R
Guru
Please check one thing you need to add one more command so that you won't get any unncessary labels from the l2 peer.
mpls ldp neigbot acl
under acl use deny any any
regards
shivlu jain
Hi, you are right!
Xconnect under an SVI interface is only support if you have SIP or ES20 facing the MPLS WAN. You need to have MPLS configured on a phisical port of the ES20.
Regards.
Max
So your saying you cannot do a hardware EoMPLS to SVI with QinQ, or is this only possible with a ES20 or SIP card?
I have EoMPLS with Sup720 (x-connect based) and SUP2 (SVI based) up and running, but I need to trunk my traffic on each side of the network with EoMPLS connecting the two.
Please see this following link to help me with EoMPLS vlan transport :
https://supportforums.cisco.com/message/3054538#3054538
