QOS for Policing Ethernet Traffic on Catalyst 3750
sherwinang
Hello!
I am running a Cisco Catalyst 3750 with IOS c3750-ipbase-mz.122-25.SEB4.bin
Since we've deployed these switched on our Metro Ethernet network, we are now needing the capability to police/rate-limit the client's ports.
I've done examples on Cisco's docs about QoS in 3750 but can't seem to get it right.
I have mls qos enabled
QoS is enabled
QoS ip packet dscp rewrite is enabled
I have placed this configurations to try to limit client traffic
class-map match-all ANY
match access-group 1
access-list 1 permit any
policy-map POLICE-TO-2MB
class ANY
police 2000000 375000 exceed-action drop
I then apply this to the client interface
interface GigabitEthernet1/0/5
description Link to Customer
switchport access vlan 12
service-policy input POLICE-TO-2MB
end
apparently, the client's input traffic, meaning his upload to me is still exceeding 2Mbits, actually it is still at 95Mbits/sec so I am really confused.
Hope you guys could give me some pointers on how to police all type of traffic on this interface.
Thanks!
tiagocarrijo
You can't use input police in normal ports in the 3750.
You need to use de ES ports.
So you can do an VLAN police rate.
Pardon me, but what do you mean by ES ports? I hope you could point me to a documentation about this or probably a simple example. Thank you.
shaner
apply the service policy to interface vlan 12, not the layer 2 switchport interface GigabitEthernet1/0/5.
This should work.
also to ratelimit egress traffic use the srr-queue bandwidth shape command. You can't do a service policy output on the 3550/3750. THere is a hardware limitation.
An ES port is found on 3750 Metro switches.
If you have the 3750 standard, you will need to aply in the vlan.
