05-04-2008 06:28 PM
Dear Cisco Team, Does the Catalyst series support MPLS, VPLS PE / P function. AFAIK only Cisco Router support MPLS, VPLS PE/P. what catalyst series support MPLS/VPLS? tq anyway
Solved! Go to Solution.
05-05-2008 01:25 AM
Cisco 6500 and 7600 but 7600 series is Leadership for such postion, 7600 with RSP720 comes with very large MAC (CAM)table to support Metro-ethernet.
Hope that help.
Please rate helpful posts.
Best Regards,
Mounir Mohamed
05-05-2008 01:25 AM
Hope that help.
Best Regards,
Mounir Mohamed
05-05-2008 11:00 PM
Would you marked the conversation as solved if you case has been solved.
