6PE Route Reflector route-map problem
DavideL3
I have a weird problem.
I set up 6PE using an old ASR1000 as route-reflector.  (IOS XE version 03.16.09.S).
The RR eceive prefixes from 6PE enable routers and reflect them correctly.
If I try to configure an outgoing route-map to a specific peer the RR stop sending prefixes to this last peer.
I see that prefixes are all dropped:
                                             Outbount  Inbound
Local Policy Denied Prefixes: -------- -------
Other Policies:                           1              n/a
Invalid Labels:                            6              n/a
Total:                                         7                0
The route-map is matiching either community and ipv6 prefix-list
What I'm wrong ?
Davide
2 Accepted Solutions
Hello Elvin,
I resolved the issue.  I was missing a specific "set" into route map:
Here's the output:
route-map 6PE-PADOVA-OUT permit 10
match community PE-PADOVA-LB
set mpls-label
What I was expecting ; ). If you set a route-map policy, the label is not set by default, and the device will drop the update.
Good to know all is solved now.
Elvin
Elvin Arias
What is the configuration that is dropping the v6 prefixes?
Elvin
Hello Elvin,
Here's the output:
set mpls-label
Elvin
