6VPE on XRV9K(ping not working)
sachin30720041
I have the following setup. int lo1 is under vrf1 on XRV9K1 and XRV9K2.
IPV4 and ipv6 routes are exchanged. Ping between the vpnv4 route works.
XRV9K1#ping vrf vrf1 22.22.22.22 source 11.11.11.11
Sat Sep 3 22:41:57.832 UTC
Sending 5, 100-byte ICMP Echos to 22.22.22.22, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 7/14/39 ms
But ping between the vpnv6 does not work.
XRV9K1#ping vrf vrf1 22::22 source 11::11
Sending 5, 100-byte ICMP Echos to 22::22, timeout is 2 seconds:
.UUUU
Success rate is 0 percent (0/5)
XRV9K1-----XRV9K2
Below is the configuration.
XRV1
vrf vrf1
address-family ipv4 unicast
export route-target 1:1
no import route-target 1:1
import route-target 2:2
exit
address-family ipv6 unicast
exit
int gi0/0/0/0
ipv4 address 100.10.20.1 255.255.255.0
ipv6 address 100:10:20::1/64
no sh
int lo0
ipv4 address 1.1.1.1 255.255.255.255
ipv6 address 1::1/128
exit
int lo1
vrf vrf1
ipv4 address 11.11.11.11 255.255.255.255
ipv6 address 11::11/128
exit
mpls ldp
exit
router isis 1
net 49.0001.1111.1111.1111.00
is-type level-2
mpls ldp auto-config
metric-style wide
exit
metric-style wide
exit
int gi0/0/0/0
exit
exit
int lo0
exit
exit
router bgp 12
exit
address-family vpnv4 unicast
exit
address-family vpnv6 unicast
exit
neighbor 2.2.2.2
remote-as 12
update-source lo0
exit
neighbor 2::2
remote-as 12
update-source lo0
exit
vrf vrf1
rd 1:1
network 11.11.11.11/32
exit
network 11::11/128
exit
XRV2
vrf vrf1
export route-target 2:2
exit
exit
int gi0/0/0/0
ipv4 address 100.10.20.2 255.255.255.0
ipv6 address 100:10:20::2/64
no sh
int lo0
ipv4 address 2.2.2.2 255.255.255.255
ipv6 address 2::2/128
exit
int lo1
vrf vrf1
ipv4 address 22.22.22.22 255.255.255.255
ipv6 address 22::22/128
exit
mpls ldp
exit
router isis 1
net 49.0002.2222.2222.2222.00
is-type level-2
metric-style wide
exit
metric-style wide
exit
int gi0/0/0/0
exit
exit
int lo0
exit
exit
exit
router bgp 12
exit
exit
exit
neighbor 1.1.1.1
remote-as 12
update-source lo0
exit
neighbor 1::1
remote-as 12
update-source lo0
exit
vrf vrf1
rd 2:2
network 22.22.22.22/32
exit
network 22::22/128
exit
Sachin
Harold Ritter
Hi @sachin30720041 ,
The issue is that you use the IPv6 neighbor (22::22) for the VPNv6 session. Since you have not configured LDPv6, there is no LSP to that IPv6 neighbor and therefore the recursive lookup will not work for the IPv6 prefixes in the VRF. There are two solutions to fix it:
1- configure address-family vpnv6 under the ipv4 neighbor (2.2.2.2)
router bgp 12
neighbor 2.2.2.2
or
2- enable LDPv6
mpls ldp
address-family ipv6
interface gi0/0/0/0 address-family ipv6
Bear in mind that solution 1 is the one currently being used by most service providers deploying vpnv6, as they have ipv4 enable MPLS cores, and not necessarily an ipv6 enabled MPLS core.
Harold Ritter
router bgp 12
neighbor 2.2.2.2
or
2- enable LDPv6
mpls ldp
address-family ipv6
