Causes of MPLS Label Drop
rmnepomuceno
One of our customer sometimes experience a loss of connectivity on a certain network prefix but this network prefix is reachable from the CE router and is present on the local router. From the local PE router the network prefix is reachable but from other PE router it is unreachable. The odd thing is when we check on other PE router the forwarding table it show label are being drop. The only solution we only provided on the network prefix is to clear only that router not the whole routing table on the the vrf table. Have experience this kind of problem before.
shivlu jain
Level 5
Level 5
hi
yes we faced such type of problems in our network also. Is is actually the malfunctioning of IOS; To come out form the probelm need to clear the vrf routing table. OR sometimes you need to remove the vrf and clear the mp-bgp enteries of the vrf.
regards
shivlu
Hi shivlu,
Thnks for sharing your experience regarding this problem. Mostly when we encountered this kind of problem what we normally do is to "clear vrf ip prefix" and then the problem is fixed now. What I am concerned with this kind of approach is that in the first place is that I should'nt do any kind of clearing of a certain route that should be dynamically done by the router.
Guys, shivlu do you know any kind of information what cause for the MPLS label to be dropped.
Kind regards,
renan
