CE to PE OSPF
maher
Hi there,
Normally, at PE, the route of particular VRF is shown as a BGP.I would like to know, it is a normal when there is an OSPF route like below example:
PE#sh ip route vrf vrf1
Routing Table: vrf1
Gateway of last resort is not set
192.168.1.0/32 is subnetted, 1 subnets
O 192.168.1.1 [110/11] via 200.0.0.106, 00:05:15, FastEthernet1/0
192.168.2.0/32 is subnetted, 1 subnets
B 192.168.2.1 [200/11] via 200.0.0.10, 03:42:13
200.0.0.0/30 is subnetted, 2 subnets
B 200.0.0.112 [200/0] via 200.0.0.10, 05:48:31
C 200.0.0.104 is directly connected, FastEthernet1/0
Thanks in advance.
maher
romccallum
Level 4
Level 4
It is absolutely fine. All that has been done here is that the peering between CE and PE is done using OSPF. Perfectly normal and perfectly acceptable.
Thanks for the info.Just curious about OSPF leak into global routing table..just to make sure, whether a correct configuration.
thanks again.
maher
