configuring bgp evpn with Cisco CSR
sachin30720041
Hello All,
I am new to the BGP EVPN configuration on the cisco CSR.
I have 4 routers.
R1------R2
R3          R4
R1 and R2 have a BGP EVPN session between them.
lo0 of R1=11.11.11.11
lo0 of R2=22.22.22.22
gig3 of R1 is connected with gig0/0 of r3.
gig3 of R2 is connected with gig0/0 of r4.
R1:-
router bgp 100
 bgp router-id 11.11.11.11
 bgp log-neighbor-changes
 no bgp default ipv4-unicast
 neighbor 22.22.22.22 remote-as 200
 neighbor 22.22.22.22 ebgp-multihop 255
 neighbor 22.22.22.22 update-source Loopback0
 address-family ipv4
 exit-address-family
 address-family l2vpn evpn
  neighbor 22.22.22.22 activate
  neighbor 22.22.22.22 send-community both
 exit-address-family
 address-family ipv4 vrf vrf1
  advertise l2vpn evpn
  redistribute connected
 exit-address-family
interface GigabitEthernet3
 vrf forwarding vrf1
 ip address 100.10.10.1 255.255.255.0
end
R2:-
router bgp 200
 bgp router-id 22.22.22.22
 neighbor 11.11.11.11 remote-as 100
 neighbor 11.11.11.11 ebgp-multihop 255
 neighbor 11.11.11.11 update-source Loopback0
 address-family ipv4
 exit-address-family
  neighbor 11.11.11.11 activate
  neighbor 11.11.11.11 send-community both
 exit-address-family
 address-family ipv4 vrf vrf2
 exit-address-family
 vrf forwarding vrf1
end
Bgp evpn session is up. But I am not able to ping between R3 and R4.
I am not seeing 'MAC/IP advertisement route' route type on the CSRs.
r1#show bgp l2vpn evpn
BGP table version is 8, local router ID is 11.11.11.11
Route Distinguisher: 1:1 (default for vrf vrf1)
 *>   [5][1:1][0][24][100.10.10.0]/17
                      0.0.0.0                  0         32768 ?
Route Distinguisher: 2:2
 *>   [5][2:2][0][27][10.1.1.0]/17
                      22.22.22.22                            0 200 ?
Are there any good resources/tutorials to learn BGP EVPN configuration on the CSR routers?
2 Accepted Solutions
Harold Ritter
Level 12
Level 12
Hi @sachin30720041 ,
You can use the following guide.
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/mp_l2_vpns/configuration/xe-16-8/mp-l2-vpns-xe-16-8-book/evpn-single-homing.html
Bottom line is that you need to configure the customer facing interface something like this.
l2vpn evpn instance 10 vlan-based
bridge-domain 10
member GigabitEthernet3 service-instance 10 member evpn-instance 10 !
interface GigabitEthernet3 service instance 10 ethernet encapsulation dot1q 10 !
And if you want to configure and IP address and VRF interface you need to use a bridge-domain interface (BDI).
interface BDI10
vrf forwarding vrf1
encapsulation dot1Q 10
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
The issue is due to a limitation on the CSR1000v. It does not work when you configure a subinterface with dot1q encapsulation. This is why the ping doesn't work from one CE to the other. I would suggest applying the following configuration on the two CEs.
CE1:
no interface gi1.10
interface gi1
bridge-domain 10
member GigabitEthernet1 service-instance 10
interface BDI10
ip address 100.10.10.10 255.255.255.0
no shutdown
CE2:
no interface gi1.10
interface gi1
bridge-domain 10
interface BDI10
ip address 100.10.10.20 255.255.255.0
no shutdown
This should fix the issue.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Harold Ritter
Level 12
Level 12
bridge-domain 10
interface BDI10
vrf forwarding vrf1
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Hi Harold,
r1-----r2----r3----r4
R1's loopback:- 11.11.11.11
R2's loopback:-22.22.22.22
R2's Gi3 is connected with R1's gi1
R3's gi3 is connected with R4's gi1
I followed the tutorial you mentioned in the previous post. but ping between R1 and R4 is not working. I am using CSR1000V routers.
Config on R2:-
router bgp 1
address-family ipv4
exit-address-family
neighbor 22.22.22.22 send-community extended
exit-address-family
bridge-domain 10
mac aging-time 30
l2vpn evpn
replication-type ingress
mpls label mode per-ce
router-id Loopback0
rd 1:1
route-target export 1:1
route-target import 1:1
route-target import 2:2
no auto-route-target
no ip address
negotiation auto
no mop enabled
no mop sysid
R3:-
router bgp 2
address-family ipv4
exit-address-family
neighbor 11.11.11.11 send-community extended
exit-address-family
l2vpn evpn
router-id Loopback0
rd 2:2
route-target export 2:2
bridge-domain 10
mac aging-time 30
no ip address
negotiation auto
no mop enabled
no mop sysid
R1:-
interface GigabitEthernet1.10
end
R4:-
Sachin
CE1:
no interface gi1.10
interface gi1
bridge-domain 10
interface BDI10
no shutdown
CE2:
no interface gi1.10
interface gi1
bridge-domain 10
interface BDI10
no shutdown
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
