Enabling restapi on cisco XE
sachin30720041
Hello All,
I am trying to enable rest API on the cisco XE router. I used the following command to enable rest API.
remote-management
restful-api
But when I execute the following command from a Linux box I get the following error.
curl -i -k -X "OPTIONS" "https://192.168.0.55/api/v1/l2interfaces" -H 'Accept:application/json' -u 'username:password'
curl: (35) error:14004438:SSL routines:CONNECT_CR_SRVR_HELLO:tlsv1 alert internal error
what does this error mean? And how can I confirm if the rest API is configured correctly?
Sachin
5 Replies 5
balaji.bandi
Thanks for responding.
I followed the tutorial that you forwarded.
According to the tutorial to deploy the restapi use the following command.
curl -v -X POST https://192.168.0.57/api/v1/auth/token-services -H "Accept:application/json" -u "sachin:123456" -d "" --insecure -3
But when I used it I still get the same error. How can I make sure if the rest API is enabled on Cisco XE? Is there any show command to check if rest api is enabled?
Sachin
provide more information now, what model of the device and code is running and full show run for us to understand the issue.
BB
Hello Balaji,
I am following the above-mentioned tutorial. I used the following command to deploy rest api but I received 404 response. Command
curl -v -X POST https://192.168.0.15/api/v2/auth/token-services -H "Accept:application/json" -u "sachin:123456" -d "" --insecure -3
Warning: Ignores instruction to use SSLv3
Note: Unnecessary use of -X or --request, POST is already inferred.
*   Trying 192.168.0.15:443...
* Connected to 192.168.0.15 (192.168.0.15) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
* successfully set certificate verify locations:
*  CAfile: /etc/ssl/cert.pem
*  CApath: none
* TLSv1.2 (OUT), TLS handshake, Client hello (1):
* TLSv1.2 (IN), TLS handshake, Server hello (2):
* TLSv1.2 (IN), TLS handshake, Certificate (11):
* TLSv1.2 (IN), TLS handshake, Server key exchange (12):
* TLSv1.2 (IN), TLS handshake, Server finished (14):
* TLSv1.2 (OUT), TLS handshake, Client key exchange (16):
* TLSv1.2 (OUT), TLS change cipher, Change cipher spec (1):
* TLSv1.2 (OUT), TLS handshake, Finished (20):
* TLSv1.2 (IN), TLS change cipher, Change cipher spec (1):
* TLSv1.2 (IN), TLS handshake, Finished (20):
* SSL connection using TLSv1.2 / ECDHE-RSA-AES128-GCM-SHA256
* ALPN, server accepted to use http/1.1
* Server certificate:
*  subject: CN=IOS-Self-Signed-Certificate-1335733482
*  start date: Apr 12 18:15:25 2022 GMT
*  expire date: Apr 11 18:15:25 2032 GMT
*  issuer: CN=IOS-Self-Signed-Certificate-1335733482
*  SSL certificate verify result: self signed certificate (18), continuing anyway.
* Server auth using Basic with user 'sachin'
> POST /api/v2/auth/token-services HTTP/1.1
> Host: 192.168.0.15
> Authorization: Basic c2FjaGluOjEyMzQ1Ng==
> User-Agent: curl/7.77.0
> Content-Length: 0
> Content-Type: application/x-www-form-urlencoded
* Mark bundle as not supporting multiuse
< HTTP/1.1 404 Not Found
< Server: openresty
< Date: Tue, 12 Apr 2022 18:40:33 GMT
< Transfer-Encoding: chunked
< Connection: keep-alive
< Accept-Ranges: none
< X-XSS-Protection: 1; mode=block
< X-Content-Type-Options: nosniff
< X-Frame-Options: SAMEORIGIN
< Strict-Transport-Security: max-age=7884000
404 Not Found
Below is the configuration of the CSR.
R1#show running-config
Building configuration...
hostname r1
boot-start-marker
boot-end-marker
no logging console
enable password 123456
transport-map type persistent webui map1
 secure-server
aaa new-model
aaa session-id common
ip domain name r1.example.com
login on-success log
subscriber templating
crypto pki trustpoint TP-self-signed-1335733482
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-1335733482
 revocation-check none
 rsakeypair TP-self-signed-1335733482
crypto pki trustpoint SLA-TrustPoint
 enrollment pkcs12
 revocation-check crl
license udi pid CSR1000V sn 9DKYG2RHNPT
diagnostic bootup level minimal
memory free low-watermark processor 71507
username sachin privilege 15 password 0 123456
redundancy
interface GigabitEthernet1
 ip dhcp client client-id ascii cisco-5000.0001.0000-Gi1
 ip address 192.168.0.17 255.255.255.0
 negotiation auto
 no mop enabled
 no mop sysid
interface GigabitEthernet2
 no ip address
 negotiation auto
 no mop enabled
 no mop sysid
interface GigabitEthernet3
 no ip address
 negotiation auto
 no mop enabled
 no mop sysid
interface GigabitEthernet4
 no ip address
 negotiation auto
 no mop enabled
 no mop sysid
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http client source-interface GigabitEthernet1
ip ssh version 2
control-plane
line con 0
 stopbits 1
line vty 0 4
 transport input ssh
line vty 5 15
 transport input ssh
transport type persistent webui input map1
call-home
email address to send SCH notifications.
 contact-email-addr sch-smart-licensing@cisco.com
 profile "CiscoTAC-1"
  active
  destination transport-method http
end
sachin30720041
I am trying to enable restapi on CSR routers.
Router#show version
Cisco IOS XE Software, Version 17.03.02
Cisco IOS Software [Amsterdam], Virtual XE Software (X86_64_LINUX_IOSD-UNIVER SALK9-M), Version 17.3.2, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2020 by Cisco Systems, Inc.
Compiled Sat 31-Oct-20 13:16 by mcpre
