Ethernet over MPLS query about connecting cusomers
Asemmoqbel
Dear Beloved engineers,
direct to my question without longer intro, I'm trying to establish a l2vpn between customer sites via Etherent over mpls. we want to connect the customer A site with vlan tagged and customer B site with untagged vlan.
We tried to configure one side with vc type 4 using vlan mode and other side with type 5 etherent type but VC never comes up. I did a research on cisco threads and i found this note qutoed as below
  • For a particular EoMPLS connection, both the ingress EoMPLS interface on the ingress PE and the egress EoMPLS interface on the egress PE have to be subinterfaces with dot1Q encapsulation or neither is a subinterface.)
is that means we can't mix connection VC between type 4 and type 5. if no, can you please provide other alternatives to meet our needs.
Thanks in advanced.
Hey.
Yes I've tested it on Virl and GNS3 as I don't have 2 physical routers right now to build it up.
Can you configure a pseudowire and forcing the type as ethernet like:
pseudowire-class TEST
encapsulation mpls
interworking ethernet
and then apply it to the xconnect ?
thanks
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
17 Replies 17
Francesco Molino
In order to show you the config, I've done a quick design that looks like yours:
On CE1:
interface Ethernet0/1
switchport mode trunk
duplex auto
no cdp enable
end
CE1(config-if)#do sh run int e0/0
Building configuration...
Current configuration : 93 bytes
interface Ethernet0/0
switchport access vlan 10
switchport mode access
duplex auto
end
On CE2:
duplex auto
no cdp enable
spanning-tree portfast
end
CE2#sh run int e0/0
duplex auto
end
On R1:
R1#sh run int e0/0
Current configuration : 44 bytes
no ip address
end
R1#sh run int e0/0.10
Current configuration : 109 bytes
interface Ethernet0/0.10
encapsulation dot1Q 10
xconnect 3.3.3.3 1 encapsulation mpls pw-class MPLS
end
R1#sh run | sec pseudo
pseudowire-class MPLS
encapsulation mpls
R1#sh ip int bri | ex unas
Ethernet0/1 10.2.0.1 YES manual up up
Loopback0 1.1.1.1 YES manual up up
R1#sh mpls ldp bindings
lib entry: 1.1.1.1/32, rev 2
local binding: label: imp-null
remote binding: lsr: 2.2.2.2:0, label: 17
remote binding: lsr: 3.3.3.3:0, label: 18
lib entry: 2.2.2.2/32, rev 4
local binding: label: 16
remote binding: lsr: 2.2.2.2:0, label: imp-null
remote binding: lsr: 3.3.3.3:0, label: 16
lib entry: 3.3.3.3/32, rev 6
local binding: label: 17
remote binding: lsr: 2.2.2.2:0, label: 16
remote binding: lsr: 3.3.3.3:0, label: imp-null
lib entry: 10.2.0.0/24, rev 8
remote binding: lsr: 3.3.3.3:0, label: 17
lib entry: 10.2.1.0/24, rev 10
local binding: label: 18
R1#sh mpls l2transport vc
Local intf Local circuit Dest address VC ID Status
Et0/0.10 Eth VLAN 10 3.3.3.3 1 UP
R1#
On R2:
R2#sh run int e0/0
Current configuration : 97 bytes
no ip address
xconnect 1.1.1.1 1 encapsulation mpls pw-class MPLS
end
R2#sh ip int bri | ex unas
Ethernet0/1 10.2.1.3 YES manual up up
Loopback0 3.3.3.3 YES manual up up
R2#sh run | sec pseudo
encapsulation mpls
R2#sh mpls ldp bindings
lib entry: 1.1.1.1/32, rev 10
remote binding: lsr: 1.1.1.1:0, label: imp-null
lib entry: 2.2.2.2/32, rev 2
remote binding: lsr: 1.1.1.1:0, label: 16
lib entry: 3.3.3.3/32, rev 4
remote binding: lsr: 1.1.1.1:0, label: 17
lib entry: 10.2.0.0/24, rev 6
lib entry: 10.2.1.0/24, rev 8
remote binding: lsr: 1.1.1.1:0, label: 18
R2#sh mpls l2transport vc
Et0/0 Ethernet 1.1.1.1 1 UP
R2#
As you can see both side have established connection negotiating vc type Ethernet:
On R1:
R1#sh mpls l2transport binding
Destination Address: 3.3.3.3,VC ID: 1
Local Label: 20
Cbit: 1, VC Type: Ethernet, GroupID: 0
MTU: 1500, Interface Desc: n/a
VCCV: CC Type: CW [1], RA [2]
CV Type: LSPV [2]
Remote Label: 22
CV Type: LSPV [2]
R1#
On R2:
R2#sh mpls l2transport binding
Destination Address: 1.1.1.1,VC ID: 1
Local Label: 22
CV Type: LSPV [2]
Remote Label: 20
CV Type: LSPV [2]
I tried to reproduce your design by setuping 1 side using trunk and subinterface and on the other a simple access port without subinterfaces (untagged).
Is that what you tried to achieve?
Francesco
Dear Francesco,
I tried to do the same as you did but it didn't work.
The VC shows down as below
Fa2/0.50 Eth VLAN 50 3.3.3.3 1 DOWN
Let's focuse on R1 and R2 configuration because CE doesn't play a role in esatblishing L2 vpn mpls circuit.
In R1, there is a vlan and subinterface configured and in R2, etherenet access port without vlan. this is exactly what I want but I keep trying no sucess even though the configuration doesn't seem much complex.
I noticed you configured Psudowire class which only establish virtual point to point connection and encapsulating Mpls packets. I guess using xconnect to create VC and encapsutalting mpls packets enough.
I'm looking forward to hear positive feed back from you,,
Please provide the detailed show vc output.
I will list below configuration for PE1 and PE2.
PE1 configuration
PE1#sh run
Current configuration : 1926 bytes
version 12.4
hostname PE1
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
no ip icmp rate-limit unreachable
ip cef
no ip domain lookup
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
mpls label protocol ldp
archive
log config
hidekeys
ip tcp synwait-time 5
pseudowire-class mpls
encapsulation mpls
interface Loopback0
ip address 1.1.1.1 255.255.255.255
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.10
xconnect 3.3.3.3 10 encapsulation mpls
interface FastEthernet0/0.20
encapsulation dot1Q 20
xconnect 3.3.3.3 20 encapsulation mpls
interface FastEthernet0/0.30
encapsulation dot1Q 30
xconnect 3.3.3.3 30 encapsulation mpls
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial1/0
no ip address
shutdown
serial restart-delay 0
interface Serial1/1
mpls ip
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
interface FastEthernet2/0
no ip address
duplex auto
speed auto
xconnect 3.3.3.3 1 encapsulation mpls pw-class mpls
router ospf 1
router-id 1.1.1.1
log-adjacency-changes
network 1.1.1.1 0.0.0.0 area 0
network 192.168.1.0 0.0.0.255 area 0
ip forward-protocol nd
no ip http server
no ip http secure-server
mpls ldp router-id Loopback0
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
PE1#sh mpls l2transport vc
Fa2/0 Ethernet 3.3.3.3 1 DOWN
Fa0/0.10 Eth VLAN 10 3.3.3.3 10 UP
Fa0/0.20 Eth VLAN 20 3.3.3.3 20 UP
Fa0/0.30 Eth VLAN 30 3.3.3.3 30 UP
PE1#
PE2 Configuration
PE2#sh run
Current configuration : 1981 bytes
version 12.4
hostname PE2
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
archive
log config
hidekeys
encapsulation mpls
interface Loopback0
ip address 3.3.3.3 255.255.255.255
no ip address
duplex auto
speed auto
xconnect 1.1.1.1 10 encapsulation mpls
xconnect 1.1.1.1 20 encapsulation mpls
xconnect 1.1.1.1 30 encapsulation mpls
no ip address
shutdown
duplex auto
speed auto
interface Serial1/0
ip address 192.168.2.1 255.255.255.0
mpls ip
interface Serial1/1
no ip address
shutdown
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
no ip address
duplex auto
speed auto
interface FastEthernet2/0.50
encapsulation dot1Q 50
xconnect 1.1.1.1 1 encapsulation mpls pw-class mpls
router ospf 1
router-id 3.3.3.3
network 3.3.3.3 0.0.0.0 area 0
network 192.168.2.0 0.0.0.255 area 0
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
PE2#sh mpls l2transport vc
Fa2/0.50 Eth VLAN 50 1.1.1.1 1 DOWN
Fa0/0.10 Eth VLAN 10 1.1.1.1 10 UP
Fa0/0.20 Eth VLAN 20 1.1.1.1 20 UP
Fa0/0.30 Eth VLAN 30 1.1.1.1 30 UP
PE2#
Please provide sh mpls l2transport vc 1 detail
Detail part is important
PE1#sh mpls l2transport vc detail
Local interface: Fa2/0 up, line protocol up, Ethernet up
Destination address: 3.3.3.3, VC ID: 1, VC status: down
Create time: 00:34:37, last status change time: 00:33:45
Signaling protocol: LDP, peer 3.3.3.3:0 up
MPLS VC labels: local 22, remote 22
Group ID: local 0, remote 0
MTU: local 1500, remote 1500
Remote interface description:
Sequencing: receive disabled, send disabled
VC statistics:
packet totals: receive 0, send 0
byte totals: receive 0, send 0
packet drops: receive 0, seq error 0, send 0
Local interface: Fa0/0.10 up, line protocol up, Eth VLAN 10 up
Destination address: 3.3.3.3, VC ID: 10, VC status: up
Next hop: point2point
Output interface: Se1/1, imposed label stack {16 17}
Create time: 00:37:31, last status change time: 00:37:06
MPLS VC labels: local 16, remote 17
VC statistics:
Local interface: Fa0/0.20 up, line protocol up, Eth VLAN 20 up
Destination address: 3.3.3.3, VC ID: 20, VC status: up
Output interface: Se1/1, imposed label stack {16 16}
Create time: 00:38:29, last status change time: 00:38:04
MPLS VC labels: local 17, remote 16
VC statistics:
Local interface: Fa0/0.30 up, line protocol up, Eth VLAN 30 up
Destination address: 3.3.3.3, VC ID: 30, VC status: up
Output interface: Se1/1, imposed label stack {16 18}
Create time: 00:38:33, last status change time: 00:38:08
MPLS VC labels: local 18, remote 18
VC statistics:
PE1#
PE2#sh mpls l2transport vc detail
Local interface: Fa2/0.50 up, line protocol up, Eth VLAN 50 up
Destination address: 1.1.1.1, VC ID: 1, VC status: down
Create time: 00:39:17, last status change time: 00:39:17
Signaling protocol: LDP, peer 1.1.1.1:0 up
VC statistics:
Destination address: 1.1.1.1, VC ID: 10, VC status: up
Output interface: Se1/0, imposed label stack {17 16}
Create time: 00:43:01, last status change time: 00:42:37
VC statistics:
Destination address: 1.1.1.1, VC ID: 20, VC status: up
Output interface: Se1/0, imposed label stack {17 17}
Create time: 00:43:11, last status change time: 00:42:48
VC statistics:
Destination address: 1.1.1.1, VC ID: 30, VC status: up
Output interface: Se1/0, imposed label stack {17 18}
VC statistics:
PE2#
Can you share the output of show spanning-tree on both router?
Francesco
hi, Francesco
There is no spanning-tree protocol configured on the PE routers because they are not L3 switches as well as there is no vlan configured.
I am still thinking how could bring the vc up between different type 4 and type 5 EoMPLS.
Sorry I wasn't talking about PE but more about CE. There're switch right?
Can you run, this time on PE, the following commands:
debug mpls l2transport signaling message detail
debug mpls l2transport vc status
debug mpls l2transport vc status event
debug mpls l2transport vc event
debug mpls l2transport vc ldp
Francesco
I ran all debug commands but nothing showed up.
here is the output of sh mpls l2transport vc detail
PE1#sh mpls l2transport vc 1 detail
Create time: 02:50:53, last status change time: 02:50:01
VC statistics:
PE1#PE1#sh mpls l2transport vc 1 detail
PE2#sh mpls l2transport vc 1 detail
Create time: 02:49:45, last status change time: 02:49:45
VC statistics:
PE2#
Did you do a shut/no shut after activating debugs?
Can you run the following commands:
sh mpls l2transport pwid
sh mpls l2transport vc event-trace
sh mpls l2transport vc ssm id
Please put all outputs in a text file
Francesco
heey
I tried to do some of your given commands but not found on the list maybe it's not in gns3 virtual routers. Anyway I listed what i could in txt file, please take a look.
By the way, I found something intersting when I enabled debuging mpls l2tran vc event
*Mar 1 00:10:08.271: AToM MGR [3.3.3.3, 1]: Local end up
*Mar 1 00:10:08.275: AToM MGR [3.3.3.3, 1]: Mismatch vc type in remote label binding, local 5, remote 4
*Mar 1 00:10:08.279: AToM MGR [3.3.3.3, 1]: Invalidate vc, deactivating data plane
*Mar 1 00:10:08.291: AToM LDP [3.3.3.3]: Sending label mapping msg
vc type 5, cbit 1, vc id 1, group id 0, vc label 19, status 0, mtu 1500
this output showed when I typed debug mpls l2transport vc event, if you check above it states there mismatch vc type. I believe this is the issue. but wait a minute how it worked with you !!
Hey.
encapsulation mpls
thanks
Francesco
yes bingooooo. it worked!!
only one thing I need to understand now. traffic coming to the ingress of PE2 will be tagged with vlan 50, then how it will know to go to PE1 since it's untagged. can you just tell how the frame will be transmitted from CE1 to CE2. there is a litte confusion in here.
Thanks Deeply.
