Funny BGP output - Next-hop is self
olorunloba
Level 5
Level 5
I have the following bgp output on an ASBR, in an InterAS setup. The funny thing is that the next-hop for some of the prefixes is set to itself. See below
Route Distinguisher: 82:1
*>i2.2.2.0/24 10.1.1.3 0 100 0 ?
*> 7.7.7.0/24 172.16.111.2 0 100 200 65002 1 ?
*>i8.8.8.0/24 10.1.1.2 2 100 0 ?
*>i10.82.1.0/30 10.1.1.2 1786 100 0 ?
*>i10.82.1.0/24 10.1.1.2 0 100 0 ?
*> 13.1.1.0/24 172.16.111.2 0 100 200 65002 1 ?
*> 38.2.1.0/24 172.16.111.1 0 100 200 65002 1 ?
*> 38.3.1.0/24 172.16.111.2 0 100 200 65002 1 ?
*> 138.1.1.0/24 172.16.111.2 0 100 200 65002 1 ?
*> 153.46.1.0/24 172.16.111.2 0 100 200 65002 1 ?
*> 153.46.2.0/24 172.16.111.2 0 100 200 65002 1 ?
*> 153.46.3.0/24 172.16.111.2 0 100 200 65002 1 ?
*> 153.46.4.0/24 172.16.111.2 0 100 200 65002 1 ?
*> 153.46.100.0/22 172.16.111.2 0 100 200 65002 1 ?
*> 172.16.30.0/24 172.16.111.1 0 100 200 65002 1 ?
*>i192.168.100.0 10.1.1.2 65 100 0 ?
*> 213.112.65.0 172.16.111.2 0 100 200 65002 1 ?
*> 213.112.66.0 172.16.111.2 0 100 200 65002 1 ?
*> 213.112.67.0 172.16.111.2 0 100 200 65002 1 ?
*> 213.112.68.0 172.16.111.2 0 100 200 65002 1 ?
*> 213.112.69.0 172.16.111.2 0 100 200 65002 1 ?
*> 213.112.70.0 172.16.111.2 0 100 200 65002 1 ?
All the routes from AS 1 are coming from the same CE. There is on config to change the next-hop anywhere. There is no special config for any prefix. 172.16.111.1 is the IP address of the interface connecting it to AS 100. 172.16.111.2 is its neighbor in AS 100. Can anybody explain this?
mheusinger
Level 10
Level 10
are you sure the sending ASBR does not modify the BGP next hop?
Can you post the relevant config?
Can you post the output from
show bgp v u a 13.1.1.0
show bgp v u a 38.2.1.0
Did you issue a "clear bgp v u 172.16.111.2 in"? to refresh the VPNv4 BGP table?
Regards, Martin
Ok, I've moved forward. Setting next-hop self on the 172.16.112.1 seems to resolve the issue. However, on an eBGP session, I do not think this is required.
The other question is why all the prefixes are not affected. I realised that the prefixes affected are those that in the global routing table. So why will the router set the next-hop to itself when the prefix is in the global table.
These are the relevant configs, without the next-hop self
ASBR1-RACK1#sh run | beg router bgp
router bgp 100
no synchronization
no bgp default route-target filter
bgp log-neighbor-changes
network 0.0.0.0
network 101.101.101.0 mask 255.255.255.0
neighbor 172.16.111.1 remote-as 65001
neighbor 172.16.111.1 advertise-map def non-exist-map ASBR2
neighbor 172.16.111.1 password iementor
neighbor 172.16.113.2 remote-as 200
no auto-summary
address-family vpnv4
neighbor 172.16.111.1 activate
neighbor 172.16.111.1 send-community both
neighbor 172.16.113.2 activate
neighbor 172.16.113.2 send-community both
exit-address-family
router bgp 65001
no synchronization
network 11.11.11.0 mask 255.255.255.0
neighbor 10.1.1.254 remote-as 65001
neighbor 10.1.1.254 update-source Loopback0
neighbor 172.16.100.2 remote-as 1111
neighbor 172.16.100.2 password iementor
neighbor 172.16.111.2 remote-as 100
neighbor 172.16.111.2 password iementor
no auto-summary
neighbor 10.1.1.254 activate
neighbor 10.1.1.254 next-hop-self
neighbor 10.1.1.254 send-community both
neighbor 172.16.111.2 activate
neighbor 172.16.111.2 send-community both
exit-address-family
PE1-RACK1#sh ip bgp vpn all 38.2.1.0
BGP routing table entry for 1:1:38.0.0.0/8, version 57
Paths: (1 available, best #1, table Internet)
Advertised to non peer-group peers:
10.1.1.254 172.16.111.2
1540
172.16.200.2 from 172.16.200.2 (210.112.4.1)
Origin incomplete, metric 0, localpref 100, valid, external, best
Extended Community: RT:1:1,
mpls labels in/out 50/nolabel
BGP routing table entry for 82:1:38.2.1.0/24, version 154
Paths: (1 available, best #1, no table)
10.1.1.254
100 200 65002 1
172.16.111.1 from 172.16.111.2 (101.101.101.101)
Origin incomplete, localpref 100, valid, external, best
Extended Community: RT:82:1,
mpls labels in/out 96/118
PE1-RACK1#sh ip bgp vpn all 13.1.1.0
BGP routing table entry for 1:1:0.0.0.0/0, version 51
1540
Origin IGP, localpref 100, valid, external, best
mpls labels in/out 42/nolabel
BGP routing table entry for 82:1:13.1.1.0/24, version 139
10.1.1.254
100 200 65002 1
172.16.111.2 from 172.16.111.2 (101.101.101.101)
mpls labels in/out 95/117
PE1-RACK1#
PE1-RACK1#sh ip route 38.2.1.0
Routing entry for 38.2.1.0/24
Known via "ospf 1", distance 110, metric 20, type extern 2, forward metric 3
Last update from 12.2.1.1 on ATM1/0.10, 00:19:15 ago
Routing Descriptor Blocks:
* 12.2.1.1, from 210.112.4.1, 00:19:15 ago, via ATM1/0.10
Route metric is 20, traffic share count is 1
PE1-RACK1#sh ip route 13.1.1.0
% Network not in table
PE1-RACK1#
romccallum
Level 4
Level 4
Hi mate i thought i would post what we discussed already on email to let everyone else know who may encounter this issue. I believe this is a bug and not the way things are supposed to work. I will draw your scenario out differently to make it easier for people to understand.
P-->PE1(ABSR1-AS99)-->PE2(ASBR2-AS66)-->P-->PE3-->VRFA
OK so the link between P and PE1 of AS99 has ip address of 1.1.1.1/30 - within VRFA router there is a loopback interface which has the IP address of 1.1.1.1/30.
In this circumstance there is no way that the route from VRFA will ever be announced via PE1.WHY?? Because PE1 has that route already within its own global routing table. I have seen this on many occassions while studying for my CCIE SP and have always put it down to crappy software that i am using. Its got to be a bug otherwise there will be quite a few SP's out there who will get caught out with this when it comes time for MPLS global domination ;-). Hope this helps.
Oh and as there seems to be a new fashion for point scoring - please rate all posts.
