IOS with MPLS for 2610XM ?
dtushing123
Level 3
Level 3
There is no image with mpls that I can find, the lowest router is the 2651xm.
However for my home lab I have 2610XM maxed out with 256meg mem and 48meg flash.
Is there any IOS I can run that will allow me to configure MPLS VPN ?
13 Replies 13
spremkumar
Level 9
Level 9
Hi Darren
Did u try feature navigator tool ?
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
regds
I tried the feature navigator and cannot seem to find a simple feature definition of MPLS.
Guys I found this,
http://www.ssuet.edu.pk/~amkhan/cisco/Cisco_IOS_referance_guide.pdf
So JK is advanced enterprise I think...
CSCO10892433
Level 4
Level 4
Hi, dtushing123
I have a 2610xm with ios image c2600-ik9s-mz.123-10b.bin. It can run mpls vpn and TE very well.(except some new advanced features)
SSLIN
Correction: it should be c2600-jk9s-mz.123-10b.bin
Sorry for the messup
SSLIN
I cannot find this image, can you tell me is it advanced IP services ?
There is a c2600-ik9s-mz-123-10f.bin ?
Hi, dtushing
Please ignore my first post. There is a typo. The letter "i" and "j" look so simalar that I made a mistake when I used "cut&paste", I cut the wrong one.
c2600-ik9s-mz-123-10b.bin is an IP PLUS feature set. It doesn't support MPLS.
c2600-jk9s-mz-123-10f.bin is an ENTERPRISE PLUS feature set. It does support MPLS. As far as I tested on my router, it can support most of the features on topics like LDP, MPLS VPN, and MPLS TE.
The Feature Navigator is a helpful tool but not for MPLS. It is not that accurate to find MPLS-related features on 2600 platform like it does on other features.
As for the file, go to the Google and type the image name in the serach box and see what you can find there.
SSLIN
Thanks for all your help. I just cannot find that file anywhere, google or cisco.com.
Cisco 2600XM does not support MPLS PE. Multi-VRF CE is supported.
Best Regards
Andreas
I have not started to configure anything but want to configure MPLS P, PE, Multi VRF and use other lessor routers (probably 2500 series) as CE
Check this image out,
System image file is "flash:c2600-advipservicesk9-mz.123-10f.bin"
R3#show mpls ?
atm-ldp ATM LDP Protocol information
forwarding-table Show the Label Forwarding Information Base (LFIB)
interfaces Per-interface MPLS forwarding information
ip MPLS IP information
label Label information
ldp Label Distribution Protocol information
traffic-eng Traffic engineering information
Darren
It doesn't matter what CLI shows you. There is no garanty for a running configuration.
MPLS PE is not supported on 2600XM series.
Use 2691, 1841, 2800, 3700 ..... routers for PE role.
MultiVRF and CE role is supported down to 800 series routers.
Andreas
Just an FYI.
I now have 2 x 2610XM running as PE and 1 x 2610XM running as P with 2 x 2500 series running as CE.
This works with the 2610XM. Check it.
Image:
Darren
I found the IOS version finally.
Thanks so much for your help, it works !!
R3#show mpls ?
