Join VPLS and EoMPLS circuit together
NAGISWAREN2
Level 5
Level 5
Hi All,
I have ASR1006 IOS-XE as PE router at that have connected to other PE with same model. And I have VPLS established to provide E-LAN service. Multiple GE interface at both site have joined this VPLS group. Now that we have another PE(ISR G2 Router, for small scale use) that need to join this VPLS group. Since ISR G2 IOS do not support VPLS , we can only achieve EoMPLS(E-LINE) service.
Is there any way to Interconnect VPLS and EoMPLS.  Referring to below configuration example, can I make Service-Instance 110 as member in Bridge-Domain 10 ? Is that would eventually interconnect EoMPLS to VPLS ? All router currently in production. Any idea would be much appreciated.
l2vpn vfi context VFI-TEST                                        // VPLS
 vpn id 10
 member 10.166.10.2 encapsulation mpls
bridge-domain 10
 member GigabitEthernet0/0/0 service-instance 101
 member GigabitEthernet0/0/0 service-instance 102
 member GigabitEthernet0/0/0 service-instance 103
 member vfi VFI-TEST
interface GigabitEthernet0/0/0
 service instance 101 ethernet
  encapsulation dot1q 101
  rewrite ingress tag pop 1 symmetric
 service instance 102 ethernet
  encapsulation dot1q 102
 service instance 103 ethernet
  encapsulation dot1q 103
 service instance 110 ethernet
  encapsulation dot1q 110
  xconnect 10.200.149.110 10 encapsulation mpls                 // EoMPLS
Regards, Nagis
bhnegi
I haven't tested this but I think it should work. We can have both Eompls/VPLS in a hub and spoke topology. However since this topology is not fully meshed you  need to disable split horizon for PE2 and PE3 to talk with each other.
PE2---VPLS---PE1---EOMPLS---PE3.
PE1:
l2 vfi VPLS-10 manual
 vpn id 10
bridge-domain 10
neighbor 102.102.102.102 encapsulation mpls
neighbor 103.103.103.103 encapsulation mpls no-split-horizon
PE2:
 vpn id 10
bridge-domain 10
neighbor 101.101.101.101 encapsulation mpls
PE3:
interface GigabitEthernet0/0/2
no ip address
negotiation auto
xconnect 101.101.101.101 10 encapsulation mpls
Best Regards,
Bheem
7 Replies 7
bhnegi
PE1:
 vpn id 10
bridge-domain 10
PE2:
 vpn id 10
bridge-domain 10
PE3:
no ip address
negotiation auto
Best Regards,
Bheem
Thanks for reply. Does it mean, I do no need to do xconnect in PE2  as in my Configuration above?
Regards, Nagis
In my example, PE1 and PE2 represent your existing PE routers in VPLS domain and PE3 would be acting as ISRG2 with eompls. ISRG2 has xconnect only towards PE1 and P1 see ISRG2 as a member on VFI.
Best Regards,
Bheem
I cant fine "neighbor" command under bridge-domain nor l2vpn vfi. If the "neighbor" command replace by "member" , it should be type under VFI or Bridge-domain ?
Btw, I noticed my VFI configuration and yours different.
My config
 vpn id 10
Your Config
 vpn id 10
Regards, Nagis
Both are valid configuration. Please see link below.
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/mp_l2_vpns/configuration/xe-3s/asr1000/mp-l2-vpns-xe-3s-asr1000-book/mp-vpls.html#GUID-9C91269F-949C-4A41-8B54-FC6D354369C3
Best Regards,
Bheem
Hi ,
Thank you. That works like charm. Btw, based on my testing, If I configure member under VFI, the VC is UP but traffic cant pass through. But if configure member under Bridge-domain , then VC is UP and traffic can pass through.
Regards, Nagis
Trying to do the same thing. Any chance you could PM me/copy up your final configs from the PE1 and PE3 equivalent?
