L3VPN issue in XR
Anand Solgama
my below config of L3vpn not working. Please help me.
XR:
RP/0/0/CPU0:ios#sh run
Fri Feb  6 23:53:18.968 UTC
Building configuration...
!! IOS XR Configuration 5.1.1
!! Last configuration change at Fri Feb  6 23:43:56 2015 by anand
vrf ABC
address-family ipv4 unicast
  import route-target
   100:1
  export route-target
   100:1
interface Loopback0
ipv4 address 2.2.2.2 255.255.255.255
interface MgmtEth0/0/CPU0/0
shutdown
interface GigabitEthernet0/0/0/0
vrf ABC
ipv4 address 192.168.1.2 255.255.255.0
interface GigabitEthernet0/0/0/1
ipv4 address 200.200.200.1 255.255.255.0
interface GigabitEthernet0/0/0/2
interface GigabitEthernet0/0/0/3
interface GigabitEthernet0/0/0/4
shutdown
rd-set 1:100
  1:100
end-set
route-policy PASS
  pass
end-policy
router bgp 1000
bgp router-id 2.2.2.2
  network 2.2.2.2/32
address-family vpnv4 unicast
neighbor 3.3.3.3
  remote-as 1000
  update-source Loopback0
   route-policy PASS in
   route-policy PASS out
vrf ABC
  rd 1:100
   redistribute eigrp 10
mpls ldp
router-id 2.2.2.2
router rip
interface Loopback0
router eigrp 10
vrf ABC
  address-family ipv4
   autonomous-system 10
   redistribute bgp 1000
   interface Loopback0
end
3600:
R3#sh run
Current configuration : 2135 bytes
version 12.4
hostname R3
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
no ip icmp rate-limit unreachable
ip cef
no ip domain lookup
ip vrf ABC
rd 1:100
route-target export 100:1
route-target import 100:1
mpls label protocol ldp
ip tcp synwait-time 5
interface Loopback0
ip address 3.3.3.3 255.255.255.255
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Ethernet1/0
ip vrf forwarding ABC
ip address 192.168.2.2 255.255.255.0
half-duplex
interface Ethernet1/1
ip address 200.200.200.2 255.255.255.0
half-duplex
mpls ip
interface Ethernet1/2
no ip address
shutdown
half-duplex
interface Ethernet1/3
no ip address
shutdown
half-duplex
router eigrp 20
auto-summary
address-family ipv4 vrf ABC
redistribute bgp 1000 metric 30000 1 255 255 1500
network 3.3.3.3 0.0.0.0
network 192.168.2.0
auto-summary
autonomous-system 20
exit-address-family
router rip
version 2
network 3.0.0.0
network 200.200.200.0
router bgp 1000
no synchronization
bgp log-neighbor-changes
network 3.3.3.3 mask 255.255.255.255
neighbor 2.2.2.2 remote-as 1000
neighbor 2.2.2.2 update-source Loopback0
neighbor 2.2.2.2 route-map PASS in
neighbor 2.2.2.2 route-map PASS out
no auto-summary
neighbor 2.2.2.2 activate
neighbor 2.2.2.2 send-community both
exit-address-family
redistribute eigrp 20 metric 1
no synchronization
exit-address-family
no ip http server
no ip http secure-server
ip prefix-list PASS seq 5 permit 0.0.0.0/0 le 32
no cdp log mismatch duplex
route-map PASS permit 10
match ip address prefix-list PASS
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
vrf ABC
  import route-target
   100:1
  export route-target
   100:1
interface Loopback0
shutdown
vrf ABC
shutdown
rd-set 1:100
  1:100
end-set
route-policy PASS
  pass
end-policy
router bgp 1000
  network 2.2.2.2/32
neighbor 3.3.3.3
  remote-as 1000
vrf ABC
  rd 1:100
mpls ldp
router-id 2.2.2.2
router rip
interface Loopback0
router eigrp 10
vrf ABC
  address-family ipv4
   interface Loopback0
end
ROUTER ARE NOT PINGING EACH OTHER CUSTOMER
Thanks in advance....
pedersen
Your BGP session between the XR and the ME is only running IPv4 unicast, not M-BGPv4, you can see that in the Neighbor capabilities list doing a show BGP neighbor on ME, where you will see that:
Address family VPNv4 Unicast: advertised
But you have not recieved it, you're missing the following on the XR:
router bgp 1000
 neighbor 3.3.3.3 address-family vpnv4 unicast
commit
The clear the BGP session, and let them nengotiate the capabilities, and you should be good then.
BTW you only need a RPL attached for e-bgp neighbors, not for ibgp.
/Anders
pedersen
router bgp 1000
commit
/Anders
