[me3600] L2 control protocols rate-limit on ingress???
Carlos A. Silva
Level 3
Level 3
A customer is testing a pseudowire between an ME3600 and an ASR9001. PW works without a problem, but they found a curious situation. They decided to generate l2 control protocol flows within that PW (STP, CDP, etc).
In the TG-->ASR9001--->ME3600-->TG direction, all flows pass without a problem. But in the TG-->ME3600-->ASR9001--->TG, flow are capping at 2000 packets per second (~2.5M). Is this something that the ME3600 does by default? If yes, can this behavior be changed?
Mind you, there's absolutely no QoS-type rate-limit anywhere. Just your basic PW that's working perfectly, except for this curious note.
Thanks in advance!
c.
sreenivasgajula
Assuming you are tunneling those l2protocols across your PW? If yes, you might be right about the rate-limit. For ASR901 platform, there are such rate-limits and I'm pretty sure ME3600 being in the same portfolio has such limitations. I would recommend contacting TAC if you need specific numbers.
Here is what I know about ASR901:
• Layer 2 protocol tunneling supports a maximum packet rate of 10 packets ps (per interface) for a protocol, and 100 packets ps for all protocols (on all interfaces).
