MPLS Interface attributes
Mesho7
Community Member
I have a question about MPLS Interface attributes.
In the examples I see:
  Interface                  LDP      Tunnel   Enabled
POS0/4/0/0                 Yes      Yes      Yes
Interface - which I assume is Ethernet interface
LDP - I understand that this is LDP protocol enabled
Tunnel - documentation says "State of LSP Tunnel labelling." What is this actually ? RSVP ? TE ?
What is the difference between:
LDP labelling enabled & LSP labelling enabled
balaji.bandi
What is this actually ? RSVP ? TE ?   - This is more QOS and Trraffic Engineering  - This method determines a path through the network based on the interior gateway protocol's view of the network.
LDP  - Ladble distribution protocol which enable when you enable MPLS
LSP - Label Switched Paths - LDP used only best-effort of LSP
You can find an more information here :
https://www.cisco.com/c/en/us/td/docs/ios/mpls/configuration/guide/convert/mp_ldp_book/mp_ldp_overview.html
BB
Mesho7
Community Member
I still don't get the difference between:
LDP - State of LDP labelling.
Tunnel - State of LSP Tunnel labelling.
  Interface POS0/4/0/0:
     LSP labelling enabled (TE-Control)
     MPLS enabled
     MTU = 4474
pigallo
Hello, answers inline.
No POS actually is Packet over Sonet/SDH , so it doesn't run any ethernet encapsulation. It rather runs PPP usually...
yes, LDP indicates if LDP protocol is enabled for that interface.
it indicates the capacity of traffic engineering on the interface (see link below for confirmation).
https://www.cisco.com/c/en/us/support/docs/multiprotocol-label-switching-mpls/mpls/12492-mpls-tsh.html#mpls
LSP labelling is the result of the reservation process performed via RSVP protocol. Without RSVP, it would not be possible to signal the LSP across the core and verify requested LSP attributes hop by hop.
LDP labeling is enabled when you activate basic mpls ldp neighborship among nodes, so LDP bindings are built and labels distributed. You don't need LDP on top of MPLS TE tunnels because RSVP is responsible to carry labels within RESV messages.
Hope i was able to clarify the point.
Regards.
