03-27-2009 04:12 PM
I'm trying some configurations MPLS-TE with PBR in 7600 with SRC3 code and has not been able to make it work.
I have tried CBTS and regular autoroute tunnels and they work fine but not a regular mpls-te with PBR.
I've been following sample configurations and still not been able to make it work.
The lab has the following setup:
CE1->PE1->P->PE2->CE2
The configuration at PE1 looks like this:
interface GigaEthernet2/1
description Connection to CE1
ip vrf forwarding test
ip address 10.1.1.1 255.255.255.252
ip policy route-map PBR_in
interface Tunnel105
description MPLS-TE Test
ip unnumbered Loopback0
mpls ip !<-- also have tried without mpls
tunnel destination 172.16.100.22
tunnel mode mpls traffic-eng
tunnel mpls traffic-eng priority 3 3
tunnel mpls traffic-eng bandwidth sub-pool 250
tunnel mpls traffic-eng affinity 0x0 mask 0x0
tunnel mpls traffic-eng path-option 1000 dynamic
no routing dynamic
route-map PBR_in permit 10
match ip address CE_Loops
set mpls-label !<-- also have tried without this
set interface Tunnel105 !<-- also have tried set ip next-hop <remote-loop>
route-map PBR_in permit 100
ip access-list extended CE_Loops
10 permit ip host 1.1.1.1 host 2.2.2.2
20 permit ip host 2.2.2.2 host 1.1.1.1
And I can see the counters of Tunnel 105 going up but no response, nor any debugging related to it.
sh int tun 104
Tunnel transmit bandwidth 8000 (kbps)
Tunnel receive bandwidth 8000 (kbps)
Last input never, output 00:00:05, output hang never
Queueing strategy: fifo
Output queue: 0/0 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
2364 packets output, 168564 bytes, 0 underruns
0 unknown protocol drops
I have done "debug mpls packet" and but I can't see anything related to labels going on.
What am I missing? Is MPLS-TE with PBR really possible? How does it apply labels to the PBR packets?
William
Solved! Go to Solution.
03-27-2009 05:42 PM
Hi William,
This design is not currently supported. The tunnel interface belongs to the global routing table and the interface on which you applied your PBR belongs to a VRF.
So the VRF doesn't know the existence of your tunnel interface.
PBR with MPLS-TE works if the interface on which you apply the PBR policy belongs to the Global Routing Table as well.
Laurent.
03-27-2009 05:42 PM
Hi William,
Laurent.
03-27-2009 05:54 PM
Thanks! I misunderstood the documentation and there is a lot of misleading information in mpls-te books. That is why I was trying to figure out how that could work, specially with the labels and I was trying to test it on the lab.
Thanks again.
_W
03-27-2009 10:25 PM
Laurent
It means if the SP is using vrf for its offices in that case they won't be able to provide PBR. Any other workaround for the same.
regards
shivlu jain
03-30-2009 06:43 AM
Hi Shivlu,
To have a dedicated tunnel per VPN:
1- Static routes in the VRF should work by specifying only the tunnel interface as the outgoing interface (no next-hop).
2- Another solution can be to change the BGP NH for each VPN:
- You have two VPNs configured on PE1 and PE2
- You have two TE tunnels T1 and T2 between PE1 and PE2. PE1 is the head-end
- BGP is build over Loopback0 IP addresses as usual
The idea is to create two new loopbacks one PE2 (L1 and L2) and to configure PE2 to use those loopbacks as BGP NH:
ip vrf VPN1
bgp next-hop loopback 1
ip vrf VPN2
bgp next-hop loopback 2
Now PE1 will receive VPNv4 updates from PE2 with BGP NH set to L1 for VPN1 and L2 for VPN2
on PE1 just add two static route so each loopback will be reachable via two different TE tunnels:
ip route L1/32 T1
ip route L2/32 T2
If you have other PEs with sites connected to these VPNS as well and you are not using TE tunnels, you need to redistribute L1 and L2 into the IGP so those other PEs will have a LSP to PE2 as well.
I agree if PBR could be aware of the interface in the GRT, it would be an easier solution.
Laurent.
03-30-2009 07:04 AM
Hi Laurent
Thanks for explanation.
regards
shivlu jain
05-18-2009 07:23 AM
I understand good the solution number 2 and i didn't know that it was possible to change the next-hop for each VPN.
But my question is about the first solution (static route). If the trafic is forwarded with static route, i think that the trafic won't be forwarded with the MP-iBGP route. So, the VPN label won't be applied. I understand so how the trafic will be put from the vrf to the tunnel but if there isn't VPN label, how the trafic will go from the tunnel to the VRF of the remote PE.
Thanks for helping.
05-18-2009 05:07 PM
You're absolutely right !! ;-)
I wrote this one too fast without thinking enough. I think I had vrf leaking to GRT in mind ..
Thanks for this good catch.
Laurent.
08-03-2009 06:35 PM
Hi lauubert
If I have previous vrf that do not configured with bgp next-hop command.
The new vrf now configure with bgp next-hop command point to loopback 2 as example.
would it cause the any problem to previous vrf that default not configure with bgp next-hop command ?
ip vrf VPN1
ip vrf VPN2
ip vrf VPN3
08-04-2009 05:42 AM
By default the PE will use the loopback configured as its BGP source-address as usual so nothing to worry about.
Laurent.
