MPLS VPN over GRE Help !!!
princesai
hi all
I built a small topology on MPLS VPNS over GRE
my topology consist of 2 CE routers 2 PE routers and 2 P routers it is a flat topology where in P-P is running GRE TUNNEL and MPLS is running in PE1-P1 and P2- PE2
the running configs are as below
for PE1
hostname SE1
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
ip vrf CUS
rd 100:1
route-target export 1:100
route-target import 1:100
interface Loopback0
ip address 1.1.1.1 255.255.255.0
ip ospf network point-to-point
interface FastEthernet0/0
duplex auto
speed auto
mpls ip
interface FastEthernet0/1
ip vrf forwarding CUS
ip address 192.168.4.1 255.255.255.0
duplex auto
speed auto
router eigrp 1
auto-summary
address-family ipv4 vrf CUS
redistribute bgp 1 metric 20000 120 255 255 15000
network 192.168.4.0
no auto-summary
autonomous-system 100
exit-address-family
router ospf 1
log-adjacency-changes
network 1.1.1.0 0.0.0.255 area 0
network 192.168.1.0 0.0.0.255 area 0
router bgp 1
no synchronization
bgp log-neighbor-changes
neighbor 2.2.2.2 remote-as 1
neighbor 2.2.2.2 update-source Loopback0
no auto-summary
address-family vpnv4
neighbor 2.2.2.2 activate
neighbor 2.2.2.2 send-community extended
exit-address-family
redistribute eigrp 100
no synchronization
exit-address-family
ip http server
no ip http secure-server
mpls ldp router-id Loopback0
control-plane
line con 0
line aux 0
line vty 0 4
end
for p1
hostname P1
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
interface Tunnel0
ip address 10.1.1.1 255.255.255.0
ip ospf cost 10
ip ospf 1 area 0
mpls ip
tunnel source FastEthernet0/1
tunnel destination 192.168.2.2
ip address 192.168.1.2 255.255.255.0
duplex auto
speed auto
mpls ip
ip address 192.168.2.1 255.255.255.0
duplex auto
speed auto
router ospf 1
ip http server
control-plane
line con 0
line aux 0
line vty 0 4
end
for P2
hostname P2
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
interface Tunnel0
ip address 10.1.1.2 255.255.255.0
ip ospf cost 10
ip ospf 1 area 0
mpls ip
tunnel destination 192.168.2.1
ip address 192.168.3.2 255.255.255.0
duplex auto
speed auto
mpls ip
ip address 192.168.2.2 255.255.255.0
duplex auto
speed auto
router ospf 1
network 192.168.3.0 0.0.0.255 area 0
ip http server
control-plane
line con 0
line aux 0
line vty 0 4
end
for PE2
hostname SE2
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
ip vrf CUS
rd 100:1
interface Loopback0
ip address 2.2.2.2 255.255.255.0
ip address 192.168.3.1 255.255.255.0
duplex auto
speed auto
mpls ip
ip address 192.168.5.1 255.255.255.0
duplex auto
speed auto
router eigrp 1
auto-summary
network 192.168.5.0
no auto-summary
exit-address-family
router ospf 1
network 2.2.2.0 0.0.0.255 area 0
router bgp 1
no synchronization
neighbor 1.1.1.1 remote-as 1
neighbor 1.1.1.1 update-source Loopback0
no auto-summary
neighbor 1.1.1.1 activate
neighbor 1.1.1.1 send-community extended
exit-address-family
no synchronization
exit-address-family
ip http server
control-plane
line con 0
line aux 0
line vty 0 4
end
for CE1
hostname CE1
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
interface Loopback0
ip address 3.3.3.3 255.255.255.0
ip address 192.168.4.2 255.255.255.0
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
router eigrp 100
network 3.0.0.0
network 192.168.4.0
no auto-summary
ip http server
control-plane
line con 0
line aux 0
line vty 0 4
end
for CE2
hostname CE2
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
interface Loopback0
ip address 4.4.4.4 255.255.255.0
ip address 192.168.5.2 255.255.255.0
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
router eigrp 100
network 4.0.0.0
network 192.168.5.0
no auto-summary
ip http server
control-plane
line con 0
line aux 0
line vty 0 4
end
CE1 is attached to PE1 and CE2 is attached with PE2
my problem is when i try to ping from CE1 to CE2 my pings are getting failed but in the routing table i can see the routes of each other
I think their is a problem in My P routers
can any one help me in understanding and correct solution for this topology
2 Accepted Solutions
Mahesh Gohil
Level 7
Level 7
Hello Sai,
Weel I have tried the same and it is working with same topology..please see
CE2#ping 3.3.3.3
Sending 5, 100-byte ICMP Echos to 3.3.3.3, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 188/264/348 ms
CE1#ping 4.4.4.4
Sending 5, 100-byte ICMP Echos to 4.4.4.4, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 208/244/284 ms
Can you post output of below commands from different routers
PE1#sh mpls forwarding-table
Local  Outgoing      Prefix            Bytes Label   Outgoing   Next Hop
Label  Label or VC   or Tunnel Id      Switched      interface
16     No Label      3.3.3.0/24[V]     2280          Gi1/0      192.168.4.2
17     No Label      192.168.4.0/24[V] 1140          aggregate/CUS
18     Pop Label     10.1.1.0/24       0             Gi2/0      192.168.1.2
19     18            192.168.3.0/24    0             Gi2/0      192.168.1.2
20     19            2.2.2.0/24        0             Gi2/0      192.168.1.2
P1#sh mpls forwarding-table
16     Pop Label     1.1.1.0/24        6035          Gi1/0      192.168.1.1
18     Pop Label     192.168.3.0/24    0             Tu0        point2point
19     19            2.2.2.0/24        0             Tu0        point2point
P2#sh mpls forwarding-table
16     16            1.1.1.0/24        0             Tu0        point2point
17     Pop Label     192.168.1.0/24    0             Tu0        point2point
19     Pop Label     2.2.2.0/24        6781          Gi2/0      192.168.3.1
PE2#sh mpls forwarding-table
16     Pop Label     10.1.1.0/24       0             Gi1/0      192.168.3.2
17     16            1.1.1.0/24        0             Gi1/0      192.168.3.2
18     17            192.168.1.0/24    0             Gi1/0      192.168.3.2
19     No Label      192.168.5.0/24[V] 2280          aggregate/CUS
20     No Label      4.4.4.0/24[V]     1710          Gi2/0      192.168.5.2
Mahesh
Hi sai,
I am using c7200-adventerprisek9-mz.124-24.T4.bin IOS
Please find config attached. Also you can post output of the commands may be i can help you.
Mahesh
Mahesh Gohil
Level 7
Level 7
Hello Sai,
CE2#ping 3.3.3.3
CE1#ping 4.4.4.4
Mahesh
Thank You Mahesh for your time can you please tell me which ios version you have used for this because i was using 3660 router and my pings dint worked can you please post your running configs as well so that it will be much helpfull for me thank you in advance
cheers,
Sai
Hi sai,
Mahesh
Thank you mahesh it worked for me will be back with another problem
