whats is/will be after MPLS, please comment
m_aurangzeb
which technology is Competing MPLS Technology in other words what will be after MPLS? please comment
8 Replies 8
Harold Ritter
Muhammad,
This is the kind of question would better be answered using a crystal ball ;-) Seriously, there is a lot of discussions on the future of MPLS and some people were suggesting that Provider Backbone Transport (PBT) could even replace MPLS. I personally think MPLS is there for a while. I also believe that technologies such and PBT and others will be used as a complement to MPLS.
HI
I am student and working on MPLS and GMPLS.I am doing research and new to this subject.I need some topics for research can u help me
Ali
shivlu jain
Level 5
Level 5
I think G-MPLS will compete MPLS.
regards
http://shivlu.blogspot.com
Hi Shivlu,
You might also want to add T-MPLS to the picture.
http://en.wikipedia.org/wiki/T-MPLS
Hi hritter,
can you give us brief idea about what is T-MPLS is all about? and How will it be different from PBB?
any good document or weblink will be great help!
regards
Devang Patel
hi Hritter
Yeah I am also looking for T-MPLS. As said by devang can you put a brief of the topics and let us know how cisco is going to add up in the roadmap. I know about CRS and giving GMPLS feature kindly correct if I am wrong.
As devang wrote if possible kindly share any good docs or links which can cleary out G-MPLS & T-MPLS concept.
regards
shivlu jain
Devang,
I made a mistake when referring to MPLS-T. MPLS-T was put forward in ITU and went nowhere. What I actually meant was MPLS-TP (MPLS Transport Profile), which replaced MPLS-T (sometimes also called T-MPLS).
Here is good good document
discussing MPLS-TP:
http://ties.itu.int/ftp/public/itu-t/ahtmpls/readandwrite/doc_exchange/overview/MPLS-TP_overview-22.pdf
With MPLS-TP , you might get end to end MPLS i.e. from one CPE to other CPE over MPLS .
So you use MPLS as Access/Distribution layer and then take it that throgh IP/MPLS core. The best part is it will allow to full OAM capability and you may not required to run control plane on those access layer devices but you just configure static LSP through central NMS.
http://www.cisco.com/en/US/technologies/tk436/tk428/white_paper_c11-562013.pdf
Chintan
