Multipoint VPLS Not forwarding traffic between PE routers.
Vincent Vlk
Hello Team,
we have created a simple test-bed VPLS topology to test MPLS/VPLS switching on Huawei P-router + 3x Cisco PE-routers. The topology and configuration is as following. The VPLS seems to be signaled correctly, but NO TRAFFIC is FORWARDED ACROSS PE ROUTERS.
VPLS configurations and show commands :
C6509E-1 VPLS config:
l2 vfi vfi560 manual
 vpn id 560
 neighbor 192.168.60.28 encapsulation mpls
 neighbor 192.168.60.27 encapsulation mpls
interface Vlan560
 no ip address
 no snmp trap link-status
 xconnect vfi vfi560
end
interface GigabitEthernet5/2
 description vpls-vlan560-test-access
 switchport
 switchport access vlan 560
 switchport mode access
 spanning-tree portfast edge
end
interface Loopback5
 description vpls-test-loopback
 ip address 192.168.60.26 255.255.255.255
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip ospf network point-to-point
end
C6509E-1#show xconnect all detail
Legend:    XC ST=Xconnect State  S1=Segment1 State  S2=Segment2 State
  UP=Up       DN=Down            AD=Admin Down      IA=Inactive
  SB=Standby  RV=Recovering      NH=No Hardware
XC ST  Segment 1                         S1 Segment 2                         S2
UP     vfi  vfi560                       UP mpls 192.168.60.27:560            UP
                                                 Local VC label 1253
                                                 Remote VC label 31
                                                 pw-class:
UP     vfi  vfi560                       UP mpls 192.168.60.28:560            UP
                                                 Local VC label 1812
                                                 Remote VC label 2097
                                                 pw-class:
UP     ac   Vl560:560(Eth VLAN)          UP vfi  vfi560                       UP
            Interworking: ethernet
C6509E-2 VPLS config:
 vpn id 560
 neighbor 192.168.60.26 encapsulation mpls
interface Vlan560
 no ip address
 xconnect vfi vfi560
end
interface GigabitEthernet5/1
 switchport
end
interface Loopback5
 ip address 192.168.60.28 255.255.255.255
 no ip redirects
 no ip unreachables
 no ip proxy-arp
end
C6509E-2#show xconnect all detail
UP     vfi  vfi560                       UP mpls 192.168.60.26:560            UP
                                                 Local VC label 2097
                                                 Remote VC label 1812
                                                 pw-class:
                                                 Local VC label 2084
                                                 Remote VC label 26
                                                 pw-class:
C7604-1 VPLS config:
 vpn id 560
interface Vlan560
 no ip address
 xconnect vfi vfi560
end
interface GigabitEthernet4/1
 switchport
end
interface Loopback5
 ip address 192.168.60.27 255.255.255.255
 no ip redirects
 no ip unreachables
 no ip proxy-arp
end
C7604-1#show xconnect all detail
  SB=Standby  HS=Hot Standby     RV=Recovering      NH=No Hardware
UP pri   ac Vl560:560(Eth VLAN)          UP  vfi vfi560                       UP
UP pri  vfi vfi560                       UP mpls 192.168.60.26:560            UP
                                                 Local VC label 31
                                                 Remote VC label 1253
UP pri  vfi vfi560                       UP mpls 192.168.60.28:560            UP
                                                 Local VC label 26
                                                 Remote VC label 2084
UP pri   bd 560                          UP  vfi vfi560                       UP
Also I'am adding show module and show version outputs of PE routers:
C6509E-1#show module
Mod Ports Card Type                              Model              Serial No.
  2    4  CEF720 4 port 10-Gigabit Ethernet      WS-X6704-10GE      XXXX
  5    5  Supervisor Engine 2T 10GE w/ CTS (Acti VS-SUP2T-10G       XXXX
  6    5  Supervisor Engine 2T 10GE w/ CTS (Hot) VS-SUP2T-10G       XXXX
Mod MAC addresses                       Hw    Fw           Sw           Status
  2  0019.30ce.a6b4 to 0019.30ce.a6b7   2.6   12.2(14r)S5  15.1(2)SY5   Ok
  5  588d.09e6.a1d5 to 588d.09e6.a1dc   1.2   12.2(50r)SYS 15.1(2)SY5   Ok
  6  44d3.ca7b.cfd8 to 44d3.ca7b.cfdf   1.1   12.2(50r)SYS 15.1(2)SY5   Ok
Mod  Sub-Module                  Model              Serial       Hw     Status
  2  Centralized Forwarding Card WS-F6700-CFC       XXXX  2.0    Ok
  5  Policy Feature Card 4       VS-F6K-PFC4        XXXX  1.1    Ok
  5  CPU Daughterboard           VS-F6K-MSFC5       XXXX  1.3    Ok
  6  Policy Feature Card 4       VS-F6K-PFC4        XXXX  1.0    Ok
  6  CPU Daughterboard           VS-F6K-MSFC5       XXXX  1.1    Ok
Mod  Online Diag Status
  2  Pass
  5  Minor Error
  6  Pass
C6509E-1#show version | include IOS
Cisco IOS Software, s2t54 Software (s2t54-ADVENTERPRISEK9-M), Version 15.1(2)SY5, RELEASE SOFTWARE (fc7)
C6509E-2#show module
  1    4  CEF720 4 port 10-Gigabit Ethernet      WS-X6704-10GE      XXXX
  1  0018.199d.38d8 to 0018.199d.38db   2.4   12.2(14r)S5  15.1(2)SY5   Ok
  2  001f.9e0f.aa48 to 001f.9e0f.aa4b   2.7   12.2(14r)S5  15.1(2)SY5   Ok
  5  4403.a70a.b25b to 4403.a70a.b262   1.7   12.2(50r)SYS 15.1(2)SY5   Ok
  6  44d3.ca7b.f3e8 to 44d3.ca7b.f3ef   1.2   12.2(50r)SYS 15.1(2)SY5   Ok
  1  Centralized Forwarding Card WS-F6700-CFC       XXXX  2.0    Ok
  5  Policy Feature Card 4       VS-F6K-PFC4        XXXX 2.1    Ok
  5  CPU Daughterboard           VS-F6K-MSFC5       XXXX 2.1    Ok
  6  Policy Feature Card 4       VS-F6K-PFC4        XXXX 1.1    Ok
  6  CPU Daughterboard           VS-F6K-MSFC5       XXXX 1.3    Ok
  1  Pass
  2  Pass
  5  Pass
  6  Pass
C6509E-2#show version | include IOS
C7604-1#show module
  2    2  Route Switch Processor 720 (Active)    RSP720-3CXL-GE     XXXX
  4   48  SFM-capable 48 port 10/100/1000mb RJ45 WS-X6548-GE-TX     XXXX
  2  001b.d401.6938 to 001b.d401.693b  5.2   12.2(33r)SRB  15.3(1)S     Ok
  4  0014.f2d0.4a18 to 0014.f2d0.4a47 10.1   7.2(1)        (sierra_main Ok
  2  Policy Feature Card 3       7600-PFC3CXL       XXXX  1.0    Ok
  2  C7600 MSFC4 Daughterboard   7600-MSFC4         XXXX  1.1    Ok
  4  Cisco Voice Daughter Card   WS-F6K-VPWR-GE     XXXX  1.0    Ok
  2  Pass
  4  Pass
C7604-1#sh version | inc IOS
Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-ADVENTERPRISEK9-M), Version 15.3(1)S1, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-ADVENTERPRISEK9-M), Version 15.3(1)S1, RELEASE SOFTWARE (fc1)
All OSPF and LDP sessions are UP and RUNNING, end-to-end connectivity between Loopbacks is fully functional.
The Mikrotik CCR routers are there just for testing purposes, acting as end hosts.
Of course, I'am aware that you need more details, so please ask for any details you need.
Any help or hint would be appreciated ;-)
Thanks in advance
Vincent Vlk
13 Replies 13
filopeter
please check if all your uplinks towards the core (Po-Tru12, Po-Tru16 and Po-Tru20) use physical interfaces on the SUP2T. Afaik WS-X6704-10GE does not support VPLS.
P.
All uplinks are Supervisor ports. Sorry, I wasn't clear with my explanation.
BR,
Vincent Vlk
HW configuration of your C7604 does not support VPLS. RSP720 does not support VPLS, you need to have an ES+ line card for this. Try to configure a simple EoMPLS tunnel between your C6509s to avoid any interoperability issues between the P and PE routers and then try to configure VPLS once again only between C6509s. Please provide also show mpls l2transport vc command output.
P.
thank You for reply. Yes, we already tested direct EoMPLS between Sup2T 6509Es, and the result was the same, signaling state is OK, but data-plane traffic is not working at all.
BR,
Vincent Vlk
the way I configure vpls is as follow;
l2vpn vfi context VPLS-LABO-BRUSSELS-LABO-ANTWERP
vpn id 1
member A.A.A.A encapsulation mpls
bridge-domain 1
member Te0/0/0 service instance 100
member Te0/2/0
member vfi VPLS-LABO-BRUSSELS-LABO-ANTWERP
Kind Regards
Jan Meylaers
Well,
this is strange. Today we tested direct interconnection with Sup2T interfaces between those 6509Es, but still no traffic passes the L3-routed interconnection with VPLS :-/
Vinit Jain
Hello Vincent
I think SUP2T should support VPLS. Please refer to the below CCO documentation:
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-6500-series-switches/white_paper_c11-663645.html
Could you please share the whole configuration from both the PE routers. I will look into it.
One quick note, one of the PE's have SUP2T (active) with Minor Error. I would recommend you to perform a switchover to the other SUP2T module. Lot of times, such minor errors can lead to traffic forwarding issues.
Vinit
--Vinit
Hello Vinit,
thank You very much for your interest.
Now the configuration is very similar to the config posted above, basically without the C7604 acting as PE router.
Topology:
[HOST1]--Gi5/2--[C6509E-1]--Gi6/1----Gi6/3--[C6509E-2]--Gi5/1--[HOST2]
C6509E-1 config:
 vpn id 560
interface Vlan560
 no ip address
 xconnect vfi vfi560
end
 switchport
 no cdp enable
 l2protocol-tunnel cdp
 l2protocol-tunnel lldp
 l2protocol-tunnel stp
 l2protocol-tunnel vtp
 spanning-tree bpdufilter enable
end
interface GigabitEthernet6/1
 ip address 10.99.99.1 255.255.255.252
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 mpls ip
end
interface Loopback5
 no ip redirects
 no ip unreachables
 no ip proxy-arp
end
router ospf 5
 passive-interface Loopback5
 network 10.99.99.1 0.0.0.0 area 0
 network 192.168.60.26 0.0.0.0 area 5
 default-information originate metric 10000
C6509E-2 config:
 vpn id 560
interface Vlan560
 no ip address
 xconnect vfi vfi560
end
 switchport
 no cdp enable
end
 ip address 10.99.99.2 255.255.255.252
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 mpls ip
end
interface Loopback5
 no ip redirects
 no ip unreachables
 no ip proxy-arp
end
router ospf 5
 network 10.99.99.2 0.0.0.0 area 0
 network 192.168.60.28 0.0.0.0 area 5
Thanks in advance.
Thanks Vincent
Could you please share the below outputs:
- show mpls ldp neighbor
- ping mpls ipv4 <remote-PE-loopback> 255.255.255.255
Would also like to know if you have already performed the switchover.
I was also researching internally and noticed a defect in which the VPLS traffic forwarding stops on SUP2T when the core facing link is on the standby SUP.
CSCsw70062
It may be worth looking into it. You may try to configure graceful restart to see if it fixes the problem.
"mpls ldp graceful-restart". Configure this command on all PE routers.
Please let me know the result.
Vinit
--Vinit
Hello Vinit,
sorry for the delay, i was redirected to other tasks. We interchanged the uplinks from Standby SUP to Active SUP but the behavior is the same, all signaling is OK, but still no data-plane forwarding.
So We are going to switchover the SUPs to address the minor error statement. I will inform you afterwards.
Thanks in advance!
P.S. Can we use interfaces on Standby SUP as edge-ports to connect CE devices?
Hello Vincent
Sorry for the delayed response. I was working on setting up the lab for this problem. I have tested the config in my lab and it seems to be working fine with SUP2T.
interface GigabitEthernet1/2
switchport
switchport access vlan 100
interface TenGigabitEthernet1/4
ip address 12.12.12.2 255.255.255.252
ip ospf 100 area 0
mpls label protocol ldp
mpls ip
interface Vlan100
no ip address
xconnect vfi test
l2 vfi test manual
vpn id 100
neighbor 4.4.4.4 encapsulation mpls
Similar config on other router was used.
Thus, this config should be working and also confirms that VPLS is supported on this platform.
i am using VS-SUP2T-10G and s2t54-adventerprisek9-mz.SPA.151-2.SY5 as the IOS.
Vinit
--Vinit
It might be an typo error, but the configuration on C6509E-2 should be
 vpn id 560
and not 192.168.60.28
P.
Yes, it is a typo, thank you very much for spotting it. It is now corrected.
Vincent
