no mpls propagate-ttl
m-geisler
Hello everybody,
I am just wondering if there is any 'show' command (except 'traceroute') to verify whether 'mpls propagate-ttl' is on or off
Mike
2 Accepted Solutions
Harold Ritter
Mike,
"mpls ip propagate-ttl" is enabled by default. The best way to find out whether it is enabled or not is to do a "show runn | incl propagate".
This will tell you whether the TTL propagation is disabled for transit traffic, locally originated traffic or both.
Hope this helps,
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
mohammedmahmoud
Level 11
Level 11
By default, the mpls ip propagate-ttl command is enabled and the IP TTL value is copied to the MPLS TTL field during label imposition.
I am not kidding, but i think that you have no way except to do show run :).
router#sh run | i ttl
no tag-switching ip propagate-ttl forwarded
router#
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
Harold Ritter
Mike,
Hope this helps,
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
mohammedmahmoud
Level 11
Level 11
router#
Mohammed Mahmoud.
Hi Harold,
Sorry didn't see your reply :)
BR,
Mohammed Mahmoud.
noelf
As the other posts indicated
show run | i propagate-ttl
There are 2 options for dis-abling the ttl
forwarded and local where forwarded option allows the propagation of packets originated by the local device.
Noel
