OSPF over IPSEC with VRF
shutikov
Hello everyone. I have IPSEC between two sites, and unicast OSPF (with neighbors). IPSEC works on VRF interfaces. Problem is - all traffic between sites encrypted, but not OSPF :-(. How can I fix this? Or OSPF over IPSEC isn't supported by VRF?
3825-1#sh run
Building configuration...
Current configuration : 2279 bytes
version 12.4
hostname 3825-1
boot-start-marker
boot-end-marker
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
resource policy
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip vrf data
rd 100:1
ip vrf voice
rd 100:2
no ip ips deny-action ips-interface
username admin privilege 15 password 0 admin
crypto keyring datakey vrf data
pre-shared-key address 192.168.11.1 key cisco
crypto isakmp policy 1
encr 3des
hash md5
authentication pre-share
group 2
crypto ipsec transform-set TS esp-3des esp-sha-hmac
crypto map cm-6509 10 ipsec-isakmp
set peer 192.168.11.1
set transform-set TS
match address ACL-ALL
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
media-type rj45
negotiation auto
interface GigabitEthernet0/0.101
encapsulation dot1Q 101
ip vrf forwarding data
ip address 192.168.101.1 255.255.255.0
no snmp trap link-status
interface GigabitEthernet0/0.201
encapsulation dot1Q 201
ip vrf forwarding voice
ip address 192.168.201.1 255.255.255.0
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
media-type rj45
negotiation auto
interface GigabitEthernet0/1.11
encapsulation dot1Q 11
ip address 192.168.11.3 255.255.255.0
ip ospf network non-broadcast
crypto map cm-6509
interface GigabitEthernet0/1.21
encapsulation dot1Q 21
ip address 192.168.21.3 255.255.255.0
router ospf 1 vrf data
router-id 192.168.11.3
log-adjacency-changes
network 192.168.0.0 0.0.255.255 area 0
neighbor 192.168.11.1
ip classless
ip http server
no ip http secure-server
ip access-list extended ACL-ALL
permit ip any any
permit ospf any any
ip access-list extended ACL-C
permit ip 192.168.101.0 0.0.0.255 host 192.168.92.1
permit ip 192.168.201.0 0.0.0.255 host 192.168.92.1
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
scheduler allocate 20000 1000
end
Harold Ritter
First, the "permit ospf any any" will never be matched since it is after "permit ip any any", which matches the ospf traffic as well.
Second, from what I remember, IPsec doesn't like "any any" to be used in the ACL.
Try being more specific as follow:
permit ospf host 192.168.11.3 host 1932.168.11.1
You should also be more specific with the "permit ip any any"
Let me know if I answered your question,
Hello Harold.
IPSEC session is successfully established, packets like pings are encrypted, but OSPF packets don't.
I have had the same config before VRF, and everything worked fine. So I think problem isn't in access-lists. I've tried to change access-list, but it hasn't result.
