PBR on VRF interface
anasubra_2
Hi All,
We have a 7600 series router with 12.2(18)SXF4 and we would like to use PBR on a VRF interface and force the traffic comming from that interface to use next-hop to the vrf next-hop address on the same router bypasssing the VRF routing table on this router.Is this possible ? Any help would be really appreciated .
Anantha Subramanian Natarajan
romccallum
Level 4
Level 4
have you tried applying a route map on the vrf interface and setting the next hop to whatever you want? I dont see why normal PBR wouldnt work here!
Hi Romccallum,
Not yet amd will be trying to do that .
