Received BGP route but not able to ping
davideranalli1
Hello essays :)
something I've seen pretty often but never understood is: why we receive a route in BGP but we can't ping as seen in the output below:
R333#show ip bgp vpnv4 vrf ciaoo neighbors 3.3.3.2 received-routes
BGP table version is 6, local router ID is 30.30.30.30
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale, m multipath, b backup-path, f RT-Filter,
x best-external, a additional-path, c RIB-compressed,
Origin codes: i - IGP, e - EGP, ? - incomplete
RPKI validation codes: V valid, I invalid, N Not found
Network Next Hop Metric LocPrf Weight Path
Route Distinguisher: 3:3 (default for vrf ciaoo)
*> 11.11.11.0/24 3.3.3.2 0 2 1 i     <<<<<<<<<<<<<<<<<<<
Total number of prefixes 1
R333#ping vrf ciaoo 11.11.11.0
Sending 5, 100-byte ICMP Echos to 11.11.11.0, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Any type of help will be kindly appreciate.
David
8 Replies 8
balaji.bandi
In you case many reason i can think of.
1. you have route does not mean you can always reachable.
   - reasons may be you are not allowed ping
   - may be any ACL in place.
   - where is this IP outside network.
   - you have enough access to ping.
2. Check traceroute and see where it dropping.
3. since we do not know your topo hard to say at the moment.
but start from traceroute 1 hop at a time, until edge of your network see you can ping from your edge network device.
BB
This is MPLS VPNv4 route, the reasons why you are not able to ping can be various.
traceroute in case of MPLS will not help much, but it can, if it is allowed in the network (it usually is not)
(do not recommend to play with it in production networks)
1.check whether the source IP of the ping is reachable for the opposite side
(on opposite side, check whether it can see in pertaining vrf the route to the source IP
the same way, as you are checking for the route on your end)
2.check whether your MPLS transport is functional!! this is crucial.
Check associated label stack to your route on your router
Check assossiations of labels for destination PE router loopback along the way
  easy ...first check, whether you can ping destination PE loopback
  then do traceroute for destination PE loopback
  then check whether LDP is allowed all the way in traceroute
  and then go one hop at a time and check labels in sh mpls forwarding-table
3. If PE-CE connections are involved, you need to check routing end-to-end in both
directions, both ends.
If you want to understand this, you need to dismantle the whole problem and go
one thing at a time.
The topology is pretty simple, I am trying to reach a network two as path away, I've created a very basic lab in EVE-NG where from AS 3 I try to reach  a network in AS 1, they belong to different vrf so I've done route leaking, there are no policies denying anything bust still not able to ping, I've seen that scenario pretty often, Ive pasted a treceroute:
R333#traceroute vrf ciaoo 11.11.11.0 source loopback 0
Tracing the route to 11.11.11.0
VRF info: (vrf in name/id, vrf out name/id)
1 192.168.1.1 8 msec 8 msec 12 msec
2 * * *
3 * * *
R333#show ip vrf ciaoo
Name Default RD Interfaces
ciaoo 3:3 Lo0
Fa0/0
Davide
Can you share the lab with me?
I can load it and help.
If possible can you post all the configuration to have a look.
BB
Dear valorous helpers.
Below I've pasted the conf of the 3 routers, as we can see again from R333 we receive network from PE but can't ping
PE#sh run
ip vrf davide
rd 1:788
route-target export 1:788
route-target import 1:788
interface Loopback0
ip vrf forwarding davide
ip address 1.1.1.1 255.255.255.255
interface Loopback1
ip address 11.11.11.11 255.255.255.0
interface Ethernet0/0
dampening
no ip address
no logging event link-status
carrier-delay msec 0
interface Ethernet0/0.1601
description verso VRF ciao_R222
encapsulation dot1Q 1601
ip address 10.1.1.1 255.255.255.0
router bgp 1
bgp router-id 10.10.10.10
bgp log-neighbor-changes
no bgp default ipv4-unicast
address-family ipv4 vrf davide
network 11.11.11.0 mask 255.255.255.0
redistribute connected
neighbor 2.2.2.2 remote-as 2
neighbor 2.2.2.2 description ciao
neighbor 2.2.2.2 ebgp-multihop 3
neighbor 2.2.2.2 update-source Loopback0
neighbor 2.2.2.2 timers 5 20
neighbor 2.2.2.2 activate
neighbor 2.2.2.2 send-community both
neighbor 2.2.2.2 maximum-prefix 5000 80 warning-only
ip route vrf davide 2.2.2.2 255.255.255.255 10.1.1.2
PE#
R222#sh run
ip vrf ciao
rd 2:11
route-target import 2:11
interface Loopback0
ip vrf forwarding ciao
ip address 2.2.2.2 255.255.255.255
interface Loopback1
ip address 3.3.3.2 255.255.255.255
description to PE
ip address 10.1.1.2 255.255.255.0
interface Ethernet0/1
description to R333
router bgp 2
bgp router-id 20.20.20.20
address-family ipv4 vrf ciao
network 22.22.22.0 mask 255.255.255.0
neighbor 1.1.1.1 remote-as 1
neighbor 1.1.1.1 ebgp-multihop 3
neighbor 1.1.1.1 update-source Loopback0
neighbor 1.1.1.1 activate
neighbor 1.1.1.1 send-community both
neighbor 1.1.1.1 soft-reconfiguration inbound
neighbor 3.3.3.3 remote-as 3
neighbor 3.3.3.3 ebgp-multihop 3
neighbor 3.3.3.3 update-source Loopback1
neighbor 3.3.3.3 activate
neighbor 3.3.3.3 soft-reconfiguration inbound
exit-address-family
ip route vrf ciao 1.1.1.1 255.255.255.255 10.1.1.1
ip route vrf ciao 3.3.3.3 255.255.255.255 192.168.1.2
ip prefix-list TO_ITDNE seq 100 permit 0.0.0.0/0 le 32
ip prefix-list TO_costa seq 100 permit 0.0.0.0/0 le 32
R222#
* 1.1.1.1/32 3.3.3.2 0 2 1 ?
* 10.1.1.0/24 3.3.3.2 0 2 1 ?
* 10.92.227.164/30 3.3.3.2 0 2 1 ?
* 11.11.11.0/24 3.3.3.2 0 2 1 i
Total number of prefixes 4
R333#
R333#sh running-config
hostname R333
ip vrf ciaoo
rd 3:3
route-target export 3:3
route-target export 2:11
route-target import 3:3
interface Loopback0
ip vrf forwarding ciaoo
desc to r222
ip address 3.3.3.3 255.255.255.255
interface FastEthernet0/0
desc to r222
ip address 192.168.1.2 255.255.255.0
duplex full
router bgp 3
bgp router-id 30.30.30.30
address-family ipv4 vrf ciaoo
neighbor 3.3.3.2 remote-as 2
neighbor 3.3.3.2 ebgp-multihop 3
neighbor 3.3.3.2 update-source Loopback0
neighbor 3.3.3.2 activate
neighbor 3.3.3.2 soft-reconfiguration inbound
exit-address-family
R333#
Thank you so much.
Davide
Hi.
Follow this:
1. First, the ping from R3 must be "ping vrf ciao 11.11.11.11" not "ping vrf ciao 11.11.11.0"
2. Then, try to put under BGP vrf ciao configuration on  R3 or R2 this command "redistribute connected" or announce the network 192.168.X.X/24.  And then try the ping again, it should be work.
a.alekseev
Level 7
Level 7
probably
R333#ping vrf ciaoo 11.11.11.1
11.11.11.0 is a network address according the routing table
