Segment Routing is different by products?
mhiyoshi
Level 3
Level 3
Dear all,
I think currently Cisco's major SR supported product is IOS-XR right?
Because there is a lot of configuration examples easy to understand and some dCloud scenario which normally IOS-XR configuration and operation.
However in my understanding, other products such as ASR1K IOS-XE and Nexus3K/9K NX-OS also support but it is pretty difficult to confirm the feature difference. I appreciate if there is any pros and cons on the following products.
1.Cisco ASR9K/NCS - IOS-XR
<https://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/segment-routing/configuration/guide/b-seg-routing-cg-asr9k.html>
2.Cisco ASR1K - IOS-XE
<https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/seg_routing/configuration/xe-16-12/segrt-xe-16-12-book/use-sr-is-is.html#con_1058322>
3.Cisco Nexus3K/9K - NX-OS
<https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus3000/sw/label_switching/7x/b_Cisco_Nexus_3000_Series_NX-OS_Label_Switching_Configuration_Guide_7x/b_Cisco_Nexus_3000_Series_NX-OS_Label_Switching_Configuration_Guide_7x_chapter_0101.html#...>
<https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/7-x/label-switching/configuration/guide/b_Cisco_Nexus_9000_Series_NX-OS_Label_Switching_Configuration_Guide_7x/b_Cisco_Nexus_9000_Series_NX-OS_Label_Switching_Configuration_Guide_...>
As for the Segment Routing, I think if I can understand the following technical keyword, then it is much easier to explain for the customers who are interested in SR or equivalent demand.
Technical Keyword:
 SR-MPLS(RSVP/LDP)
 SR-MPLS(IGP)
 SRv6
 BGP-LU for interdomain between DC/Metro/WAN
 RSVP-TE to SR-TE
 On-Demand Next Hop
 Enhanced FRR (TI-LFA)
 SR-PCE(SDN) for total solution (Network Programming)
 RFC Standard Connection with third party product
Best Regards,
Masanobu Hiyoshi
pigallo
generally speaking, SR core technology is supported on all the aforementioned platforms along with SR-TE functionality.
Being used mostly in SP underlay, a solid set of sub-features was destined to XR.
This doesn't translate in lack of supported features for other platforms though.
There are some minor differences of course, but i would not personally think about those in terms of pros and cons.
