Segment Routing Label finding method
rocky2024
Level 3
Level 3
I am very new to SR world.
we are implementing SR with OSPF as IGP.
can somebody tell me how to find SR label by using various show commands?
any link or any one can share show commands in brief that will be great help me to start checking labels.
please help
13 Replies 13
balaji.bandi
Let me read document, i will come back to you thank you.
Hello, i could not able to make out from above link what is the SR label for destination/local prefix
anyone can give me small example to find out SR label ? thank you!!
you run lab ? can I see it ?~
I use
show mpls forwarding-label
Hi @rocky2024 ,
With IOS-XR you can use "show ospf sid-database" and IOS-XE "show ip ospf segment-routing sid-database". This displays the labels (SIDs) for all the routers in the segment routing domain.
fssabati
Hi @rocky2024
Good day !
QUERY :
ANSWER :
the below command can be used to check the sid and the perfix associated with the sid
COMMAND :
Show ospf database opaque-as
EX :
#show ospf database opaque-area
            OSPF Router with ID (X.X.X.X) (Process ID test)
                Type-11 Opaque Link AS Link States
  LS age: 1888
  Options: (No TOS-capability, DC)
  LS Type: Opaque AS Link
  Link State ID: 7.0.0.1
  Opaque Type: 7
  Opaque ID: 1
  Advertising Router: 1.1.0.5
  LS Seq Number: 800000d7
  Checksum: 0x7ab
  Length: 44
    Extended Prefix TLV: Length: 20
      Route-type: 5
      AF        : 0
      Flags     : 0x0
      Prefix    : 1.1.0.1/32
      SID sub-TLV: Length: 8
        Flags     : 0x40
        MTID      : 0
        Algo      : 0
        SID Index : 7>>>>> the sid value using which the label can be obtained
Sharanya
rocky2024
Level 3
Level 3
Hello Harold,
i checked in ncs540 CSG router using show ospf sid-database command. i can see many /32 loopback ips with assigned sid values manually during migration to SR
 but now what ?  means
under some vrfs many routes are there in show route vrf 3g, next hop mentioned, prefix is there but how to find out label or sid value for destination prefixes under this vrf ? 
This is vrf route table for 3g vrf
This output is for specific next hop ip for destination prefixes for 3g vrf
Output for next hop ip to see how its learning   its learning from BGP LU session built with Nokia AGG
This is show bgp all all sum output to show BGP LU session and vpnv4 Ips
This is show bgp all all sum output to show bgp LU session and vpnv4 IPs
so my query is now how to find mpls label/sid value for prefixes under vrf 3g and sid for next hop ip for 3g vrf destinations ? i am totally confused..
Hi @rocky2024 ,
Can you please explain what you mean by that?
To see what label(s) is used for a specific prefix in the VRF, you could use the following:
show cef vrf 3G_Service_HW <prefix/prefix length>
This will show you the BGP LU label, the IGP label (SR) and the service label (BGP).
Hello Harold,
> but now what ? means--- sorry please ignore this.. i was thinking so i typed that way.
i checked show cef commands i can see like below
so labels are there in above outputs after keyword "imposed" all are assigned by SR IGP or BGP ?
in below output, i can see entry only for 20462 label but not rightmost two labels .. what does this means ?
Hi @rocky2024 ,
Yes, these labels are shown regardless if they have been learnt via BGP LU, BGP VPNv4 or SR.
"show mpls forwarding" shows the content for the LFIB, which is sort of the routing table for the labels. MPLS routes the packets using the top label. In your case it is 20462. It doesn't need to know about the other labels, but the downstream routers will need to know about them.
show mpls forwarding show only the top label, cef show all labels which in your case three label.
rocky2024
Level 3
Level 3
I am really sorry.
can you pls tell me how to find prefix sid (router loopback 0) value for prefix under vrf ? to know that this particular prefix under vrf 3G_Service_HW is belongs to that router (prefix sid value) showing ?
pman
Router#show segment-routing mpls connected-prefix-sid-map local ipv4
PREFIX_SID_CONN_MAP ALGO_0
Prefix/masklen SID Type Range Flags SRGB
10.10.10.10/32 16010 Abs 1 Y
Router#show segment-routing mpls connected-prefix-sid-map ipv4
PREFIX_SID_PROTOCOL_ADV_MAP ALGO_0
Prefix/masklen SID Type Range Flags SRGB Source
1.1.1.1/32 1 Indx 1 Y OSPF Area 0 1.1.1.1
10.10.10.10/32 10 Indx 1 Y OSPF Area 0 10.10.10.10
11.11.11.11/32 11 Indx 1 Y OSPF Area 0 11.11.11.11
12.12.12.12/32 12 Indx 1 Y OSPF Area 0 12.14.12.12
13.13.13.13/32 13 Indx 1 Y OSPF Area 0 13.13.13.13
14.14.14.14/32 14 Indx 1 Y OSPF Area 0 14.14.14.14
