strange behavior on XRV
sachin30720041
I am seeing strange behavior on XRV router.
Committing the configuration fails.And when I run 'show configuration failed' then XRV says 'No such configuration item'.  What should be the solution to such issue ?
Sachin
balaji.bandi
XRV virtual have some issue randomly  i have observered this. reload the device (make sure you have enough resource available).
BB
Harold Ritter
Hi @sachin30720041 ,
Can you please let us know what is the configuration that you are trying to commit and the IOS-XR version that you are using?
Hi Harold,
this behavior is random. I am not able to reproduce it.
Sachin
