TACACS compatibility with VRF lite
hinkle
We have command authorization using TACACS currently deployed network wide. We are begining to deploy routers using VRF lite and within 6 months will deploy full MPLS over a metro-wide fiber network. TACACS is currently not supported using VRF instances and Radius does not support command authorization. My questions is what does Cisco recommend as an alternative? Does anyone else have a similar situation and/or solution?
Thanks in advance........
6 Replies 6
Harold Ritter
Level 12
Level 12
It seems like TACACS+ per VRF is what you are looking for.
Hope this helps,
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Your right, that is the most logical answer: however, in our test environment, the IP VRF command is not present when we configure TACACS+. The following is our testing setup:
2651 runing IOS version 12.2.15ZJ5
1 frame circuit with 2 PVCs
2 FastEthernet interfaces
2 vrf instances, each with one PVC and 1 FastE
aaa group server radius radius1
server-private 10.x.x.x (etc)
ip vrf forwarding inside<<<<<<<<<<<<<<<<<<<<<<<<
ip radius source-interface Loopback0
The same "aaa group" command using TACACS does not include the "ip vrf forwarding" statement.(***see below***)
rel2651(config-sg-tacacs+)#?
TACACS+ Server-group commands:
default Set a command to its defaults
exit Exit from TACACS+ server-group confguration mode
no Negate a command or set its defaults
server Specify a TACACS server
Is this an IOS specific issue?
Glenn
I think 12.3.7T will get you out of jail. This includes ip vrf forwarding within a tacacs group.
Hope this helps
Andy
Thanks Andy,
I'll check it out. Our local Cisco rep was little help on this issue, maybe it has never come up before.
Do you know if this also works with a Cat 3550 which we run VRF lite in - is there a SW that will enable this support ?
Danne,
I searched the feature navigator ( cisco.com/go/fn ) and there are only 3 IOS versions listed, none of which show support for the 3550. I wanted to use a 2651xm and it is not supported by one of these either. I needed the command level authorization TACACS gave me but it seems that Radius is the only AAA method Cisco is supporting when using VRF lite.
Some other gotcha's include DLSW and TFTP (Gee,wonder what we use that for???)
Luck to you,
